Stock Air/Fuel and aftermarket
Old Feb 26, 2007 | 11:19 PM
80210's Avatar
Will getting a full TBE or air intake (w upper and lower pipes) affect the stock air/fuel ratios negatively if everything else is let stock? Is some sort of computer re-adjustments needed?
Old Feb 26, 2007 | 11:21 PM
80210's Avatar
Perhaps it makes more sense if I quote this... "Poorly designed intakes can lead to "lean" run conditions resulting in detonation and engine damage."
Old Feb 26, 2007 | 11:22 PM
chaotichoax's Avatar
car runs big rich...a tbe won't hurt anything...you might boost a psi or two higher because of less restriction but it doesn't change your air/fuel..however to see real gains you need to be tuned for it
an intake will definitely affect your a/f ratio in a negative way...and open element filter will scramble your maf sensor readings (not good) and intakes are good for nothing unless tuned
those mods with a tune is fine but the stock intake can handle up to 400whp or so
Old Feb 26, 2007 | 11:24 PM
Originally Posted by 80210
Perhaps it makes more sense if I quote this... "All aftermarket intakes can lead to "lean" run conditions resulting in detonation and engine damage."
there I fixed that for you
if you want an intake get a tune!
Old Feb 26, 2007 | 11:25 PM
4TUN8's Avatar
Skip the air intake, get the TBE and.....GET A FLASH, you will pick up HUGE power with the flash and be very happy, on top of knowing that your car is dialed in correctly.
Old Feb 26, 2007 | 11:31 PM
80210's Avatar
But I should be fine running a TBE exhaust for a long period of time without the tune (gotta save up for vishnu)?
Old Feb 26, 2007 | 11:51 PM
you will be fine...get a cel fix
don't waste your money for a vishnu...best deal for something nice/light/cheap is the buschur bullet tbe
I have a combo...megan racing dp and tp with a turboxs catback
I like it but I like the buschur because it is lighter and the tip is more stock looking with the recessed muffler
buschurracing.com
Old Feb 27, 2007 | 12:00 AM
JTB's Avatar
JTB
There was a great deal on a used Vishnu Sig exhaust just a bit ago
You might consider a used XEDE. They seem to be selling very cheaply these days and you could then just download a map to fit your mods as you get more bits and pieces.
Edit* Also from what I understand you really need a tune to take advantage of an exhaust on a IX.
Old Feb 27, 2007 | 12:03 AM
80210's Avatar
oop nah I was talking about the vishnu tune... I have a megan exhaust
