how to remove wing?
Old Dec 25, 2007 | 10:31 PM
LoveBoost's Avatar
Just removed my wing, took about 10 minutes, and looks a HELL of a lot better IMO.. Also way better visibility when driving and a more mature look IMO. You will also get way less attention from cops.
Old Dec 25, 2007 | 11:10 PM
mitsuEVO8kid's Avatar
thats why people do it...
Old Dec 26, 2007 | 12:22 AM
WTFCIRCUS's Avatar
Originally Posted by donmeca2020
very easyt, pop trunk get an extended 10 mm socket and begin removing. takes no more then 10 mins.
Truth, Once I brought it home from the dealership it was off in 10.
Old Dec 26, 2007 | 09:09 PM
LoveBoost's Avatar
Now I'm just thinking of getting some circle black stickers to cover up the holes.. maybe OSH? would CF tape look better?
Old Dec 27, 2007 | 09:56 AM
kingman4's Avatar
vinyl overlays. get them at your local sign store.
when you put the wing back on, do you guys reuse the factory double sided tape? or use some 3m stuff?
Old Dec 27, 2007 | 10:33 AM
06SilverEvoSE's Avatar
cover the holes from underneath so you cant tell there is tape or anything on it
Old Dec 30, 2007 | 04:57 PM
stx's Avatar
stx
I cannot remove the wing from my 08 GTS. It looks to me very well glued, the fishing line didn't help at all. I'll try again at midday/sunlight.
If you have any other tips/ideas ... please let me know.
ps: Hello you all!! (first post)
Old Dec 31, 2007 | 12:20 AM
vetboss's Avatar
Just yank it off,...the wing that is. You are right, it is very well glued so it does not fly off! Give it a good pull,...again, the wing that is and you will be fine. The heat will make it easier, but probably not neccesary.
PS - I learned the hard way with my last Evo and did it right,... I just bought a RS trunk lid, had it shaved, and now I'm flossin it right son! Better yet, I have a spare lid with wing intact in case I want to be gay without getting railed in the a$$.
When I removed my wing on my VIII, there was a large amount of rust under the laft corner of the wing. Mitsubishi covered it, but the shop expereince was a nightmare. It is almost impossible to find a good shop anymore. If you need a good one on the greater D.C. area, let me know.
cya
Old Jan 12, 2008 | 04:33 PM
stx's Avatar
stx
How to remove wing on 08 Mitsubichi Lancer GTS
Job done . Thanks vetboss, and thanks to you all !
As I don't like use brute force, I used some 3D Adhesive Remover (WalMart) in addition to the fishing line and my wife . To cover the holes I used some clear tape (a thick one), I want to be able to put back the wing if needed. Still I coudn't remove the two black plastic things, any ideas on that ?
The car looks little bit more mature now, IMHO. It will look even better with tinted windows.
