Hep Super Glue Problem
Old Mar 26, 2007 | 07:13 PM
Evo Girlie's Avatar
Unhappy Hep Super Glue Problem
Hey guys i was trying to put super glue on cf badges so it would stick better and the superglue dripped on my front bumper and i cant get it off . I tried scrubbing it within 2 mins of the drip and it leave a white rough finish. Any1 know what i can use to take it off without messing up the crappy paint?????
p.s i just noticed i spelled HELP wrong ugh what a nightmare....
Old Mar 26, 2007 | 07:24 PM
4TUN8's Avatar
Maybe try some goo gone.....heat....something I dunno that sounds horrible though.
Old Mar 26, 2007 | 07:25 PM
3SgteGuru's Avatar
rubbing compound, or even a smalll brushing of 1000 grit sand paper then compound then scratch X then wax. but compound should do it. Also they have these clay bar things, try that too. READ THE INSTRUCTIONS for the clay bar, otherwise you'll f-up your paint.
Old Mar 26, 2007 | 07:38 PM
DSMEVOLUTION's Avatar
It's nearly impossible to mess up your paint with a clay bar, unless your an idiot. But then again I don't really know you..... j/k
Old Mar 26, 2007 | 07:39 PM
Blkhrt's Avatar
Shoe Goo = the best thing for the job.....
Old Mar 26, 2007 | 07:43 PM
davidevo's Avatar
using brushing than use rubbing compound to clean it, it may help, but don't brush too hard, if the print go off, you need to reprint it...holp it help.
Old Mar 26, 2007 | 08:36 PM
TeamTurtle's Avatar
A little rule about superglue: if it drips, you used too much.
Obviously.
And I don't see how clay bar would help in this situation.
Old Mar 27, 2007 | 02:16 AM
Bonestock!'s Avatar
Finger nail polish remover.
Old Mar 27, 2007 | 04:47 AM
Newfoundlancer's Avatar
Nail Polish Remover = Acetone = Bye bye paint!
Our friend "google" recommends this: http://ezinearticles.com/?How-to-Get...-Car&id=136833
If that doesn't work, I agree with the use of 1000 grit wet-sanding and compound/polish. If you don't know how to wet sand, look it up on google. Good luck!
Old Mar 27, 2007 | 04:50 AM
hksevoix's Avatar
try taking it to a detail place, they may be able to do something for you cause I had a similar incident to my other car a while back
Old Mar 27, 2007 | 04:52 AM
Evo Girlie's Avatar
thanx for the suggestions I will try some of the suggestions and let u know what works, hopefully something does cuz this sucks big time.
Bonestock!'s Avatar
You say that but have you ever tried using it on automotive paint? It works well but you have to use it very carefully.
