walbro fuel pump install newb ??
Was just wondering if you need the install kit or if you dont need it for the fuel pump? Reason I asked is I read you dont really need the install kit and I ordered the pump without it.
its better that you use the install it or the fuel pump becomes lose over time
there is a rubber fiiting below it when using the oem rubber fitting with walbro fuel pump the pump dosent have a nice fitting and it may come lose over time so better buy it.
the first time i did mine i didnt use it and the fuel pump was really noisy so i decided to buy the kit and to check it again cause of the noise it made.
i used the new rubber fitting and to my surprise the noise was gone.
there is a post somewhere in the dynoflash forums where al explains this problems and dont overtihten the bolts on the pump i broked one headstud doing this
hope this helps you
hope this helps you
