Changing Oil & Coolant
Old Apr 14, 2007 | 12:56 PM
I Kill Suckers's Avatar
Hey guys, I am new to an Evo so I just have a couple questions. I was going to change the oil and coolant in my car today and i went under it and really couldnt find anything. It looks like the front shroud is in the way.. Can someone please tell me where the oil drain plug is and how o drain the coolant out of the radiator.
Thnx
Old Apr 14, 2007 | 01:16 PM
Q@EvoPowerMods's Avatar
DUDELY---> You're gonna get a Royal Flame Job for NOT using the SEARCH function....come on mr.lazy....search and you will find this thread------>
https://www.evolutionm.net/forums/sh...ght=oil+change
Old Apr 14, 2007 | 01:18 PM
bluebyu36's Avatar
wow,dont kill yourself.....
Old Apr 14, 2007 | 01:20 PM
I'm skeered.......opps.......
Old Apr 14, 2007 | 01:26 PM
evolution_racer's Avatar
For god sakes, find somebody else to do it before you blow up your car or something
Old Apr 14, 2007 | 01:27 PM
Exciting News's Avatar
You better watch who you're addressing like that. Did you read his user-name?!! I think it'd be scarier if it was "I kill suckas" or "Sucka Killa". That's how a true "gangsta" writes it.
OP, you wouldn't happen to be a machete wielding rastafarian, would you?
Old Apr 14, 2007 | 02:26 PM
wow guys all i did was ask a simple question...I am not familiar with the way these motors were set up....thats all...And i did search i juss didnt find anything...sorry
Old Apr 14, 2007 | 02:33 PM
Chemwarrior's Avatar
If you have EVER changed engine oil in ANY car then you would have already known how to change your oil. Just find the oil pan and you will find the oil drain plug as is the case with all vehicles. Unscrew the oil pan along with the oil filter, drain the oil, replace with new filter, put drain plug back in, and then fill with proper quantity of oil. It's not rocket surgery or brain science.
Old Apr 14, 2007 | 02:58 PM
bluebyu36's Avatar
i was just joking bro most cars have a skid plate on them you have to remove them to get the the filter .....once i took it off on my evo i never put it back on good luck....
Old Apr 14, 2007 | 03:49 PM
suka-killa..or whatever your sig is..I found the link( on evoM for the oil change) in like 30 seconds....look under the car, you'll see this rather large black thing, that is the oil pan, if you look closer you'll see that it has a bolt attached to it...hence..instant oil change location....on the IX's they have a sensor attached(to the drain plug), simply follow the wire until you see a connector then unclip the wires so that you can get a socket thru the wire to the bolt/drain plug....
Why would you want to change your coolant?
