NEED HELP With Hallman MBC ....
Old May 16, 2007 | 07:04 PM
hondafan's Avatar
all the pipes are tightened securely and not leaking? a massive boost/vacuum leak would cause the car to idle high.
Old May 16, 2007 | 08:40 PM
BoOsTinGEVO190's Avatar
bro if you cant figure out what the problem is cant be anything big dude all you did is install a mbc must of pulled something off try to bring it back they way it was
Old May 16, 2007 | 08:43 PM
Max-Q's Avatar
Did you cap off the little nipple on the underside of the intake tube? Are you sure nothing is hitting/obstructing the throttle cable?
