hks tt install help
hks tt install help
So yesterday I decided to try to install the turbo timer my self. I just wanted to do the basic functions first so I unplugged the ignition harness connection and hooked the hks harness kit to it. Is that all im suppose to do? cuz when I turn the engine off the timer shuts off too. Let me know where im screwing up lol
dude... got to evomoto.com and they have instructions listed on there... it's not that hard... you just have to do some research and read... i think there is a DIY article on here also... good luck
Connect the ebrake wire, that is most likely your problem. If not play with the "M" button on the tt. The display should have a time on it I.E. 1.00 meaning the timer will count down for 1 minute, if you are in the Voltage mode the timer will not work.
you can just ground the e-brake wire anywhere if u want.
as long as it's grounded the TT will work.
dont know why u wouldnt want to connect it to the e-brake though........
