Oil Catch Can
Old Oct 20, 2007 | 09:19 AM
xxNosTankxx's Avatar
Oil Catch Can
Ok, I've searched a bunch and I'm tired of looking now.
Looking for a decent oil catch can. I was looking at TTP but I'm not biased against other brands. I don't know much about what goes into engineering these or if they're basically all the same. If you have some or know about them, post up some comments, also pics of WHERE you installed it would be nice. Thanks guys
Nick
Old Oct 20, 2007 | 10:13 AM
Robevo RS's Avatar
arc or greddy
Old Oct 20, 2007 | 12:25 PM
kreionic's Avatar
http://www.saikoumichi.com/product_line.html
Old Oct 20, 2007 | 01:06 PM
Sparkish's Avatar
I was looking for the same thing a few months ago. I went with the Saikou Michi DC3 dual chamber catch can. I'm very happy with it. I had it installed under the intake, but I just put in a new UICP, so I'm putting it next to the mini-battery. The website has some pictures of various mounting locations--http://www.saikoumichi.com/install_pics.htm
Old Oct 20, 2007 | 04:49 PM
FQ-300's Avatar
Just installed my DC3 Dual Chamber. It is a quality piece of work. I mounted it under the BCS. Plenty of room and easy to drain in that location. Nothing but positive reviews from fellow Evo owners as well.
Old Oct 20, 2007 | 06:49 PM
Saikou_kun's Avatar
Elise owners are liking the Lotus version as well
http://www.elisetalk.com/forums/showthread.php?t=46756
Old Oct 22, 2007 | 11:49 AM
BoostEEd's Avatar
I just did the same research as well and ended up with the DC3. Here is where I installed mine:
(ignore the horn, I moved it as it was in the way of th ebumper, but catch can remained in same location)
Valve cover to Intake can:
Intake to PCV can:
Old Oct 22, 2007 | 01:36 PM
hytek369's Avatar
how often do you guys drain it?
Old Nov 5, 2007 | 04:30 PM
06MRV8Killer's Avatar
+1 Anyone?
Old Nov 7, 2007 | 09:46 AM
Anyone on this? How often do you empty the catch can?
Old Nov 9, 2007 | 07:51 PM
Saikou_kun's Avatar
Drain at least every time you do an oil change. If you drive hard, or track your car, do it more often.
Draining is as easy as possible. Turn that little brass T-handle to open the valve.
Righty tighty, lefty loosey
Old Nov 10, 2007 | 02:45 PM
lemmonhead's Avatar
weaponR I use for the breather side, it fits nicely ontop of the strut bar. I use a small walmart type for the PCV valve. works great.
Old Nov 10, 2007 | 04:09 PM
Evo_Jay's Avatar
You can get a great disposable one for 3 buck at your local auto store.
Old Nov 11, 2007 | 10:38 PM
red evo8's Avatar
just make your own parts = up to about 25$ let me know if you'd like to know how
Old Nov 16, 2007 | 07:36 PM
avo3vom's Avatar
When installing a catch can on the PCV to ITM side, does the PCV valve need to be relocated so it is between the ITM and the catch can? If so how do you install it there? If the PCV valve is left between the valve cover and the catch can is there any chance the can would be over pressurized when under boost since the valve closes?
