Plz Help! weird noise
Old Mar 25, 2008 | 09:38 PM
evascst's Avatar
i have searched for quite a while now and im just getting more frustrated,
i have a loud almost clunk kind of noise when i come to a complete stop.
it doesnt happen every time and is impossible to duplicate it just happens when it wants to.
i had it about a month after i got my car and sounded like it was coming from the drivers side front but now after a minor accident and repair it sounds a little different and from the passenger side
it sounds like something is stuck and gets released at complete stop.
any insight and help would be awesome!
Old Mar 25, 2008 | 10:53 PM
RoadSpike's Avatar
any mods to the car?
Old Mar 26, 2008 | 06:37 AM
ekizenbe's Avatar
balljoint? tie rod ends?
Old Mar 26, 2008 | 06:52 AM
evascst's Avatar
its bone stock
could ball joints and tie end rods be like that within the first month of owning the car? is it something i should notice right off the bat when i see it?
thanks for giving me a idea of where to start looking ill get under her tonight and see if i can find the problem.
it seriously sounds like the brake sheild is stuck then released at the stop
like a thin metal part is held up until the very last second of the stop
Old Mar 26, 2008 | 09:36 AM
evascst's Avatar
bump!
im still searching and some things come close but i dont think its the same problem
its annoying me bad
Old Mar 26, 2008 | 09:46 AM
RoadSpike's Avatar
Ok so how about some stupid tests?
1) Is the passenger and driver seat actually still firmly bolted down (hey its happned :P)
2) Things in the trunk or spare wheel well
3) Any loose items in the engine bay :P
Old Mar 26, 2008 | 10:02 AM
evascst's Avatar
the seats are tight lol no problem there
i feel this in the floorboard thru the pedals its really getting me worked up
i seriously hate dropping so much money for a car for it to act like this
Old Mar 26, 2008 | 10:06 AM
RoadSpike's Avatar
I'm guessing your not stock enough to take it to the stealership .
I guess its time to get a prybar and test all your bushings for clunkyness along with checking the motor mounts.
Edit:
Curious where was your accident? It may be worth looking at the area if they had to take the suspension apart or half apart.
Old Mar 26, 2008 | 10:11 AM
evascst's Avatar
no im bone stock, i just dont trust the dealership, im sure they will say me racing caused it and want me to pay. id rather fix it myself.
so just wedge a bar between joins and have a blast?
Old Mar 26, 2008 | 10:13 AM
evascst's Avatar
Edit:
i nailed a javalina at a high rate of speed on the driver side front, they said just a motormount got bent and some nasty cosmetic damage. and the acd pump fell
Old Mar 26, 2008 | 10:18 AM
RoadSpike's Avatar
Basically just use that bar to place some tension on the joints and see if they bottom out. I would take a look at the changed pieces in your driver's front side since you've mentioned it.
Old Mar 26, 2008 | 10:21 AM
evascst's Avatar
ok cool thanks for the help man, do you think since they changed the motormount there is a possibilty it came loose?
i have had the car back for a week today and the noise just started monday
Old Mar 26, 2008 | 10:25 AM
RoadSpike's Avatar
There is a whole range of things that could of happened but lets just start there since that was changed last
Old Mar 26, 2008 | 10:40 AM
evascst's Avatar
lol damn
i assume its that or break related cuz it only happens once in a while.
i drove up and down my street last night and it only did it once. i stopped maybe 20 times befor i just gave up.
Old Mar 27, 2008 | 06:51 AM
evascst's Avatar
bump!
i figured out how to recreat the noise. it only happenes after the car has been turned off and back on. it only happens once after that. but at a red light i turn the car off and at the next red light ill get the noise again.
i dont see how that could make a difference any ideas
