Best exhaust system
Old Jun 16, 2008 | 12:06 AM
  #61
importjake00's Avatar
Originally Posted by IDRINKV8'S
I almost went with ets but when i saw my friend's car on the dyno saw the number's i was sold on it.
what exhaust does your friend have?
Old Jun 16, 2008 | 12:08 AM
  #62
IDRINKV8'S's Avatar
Turbo demon you have no clue what your taking about the cobb i agree but for the greedy it's the biggest pieace of junk you can buy it's not even a true 3inch if you don't believe me they compared the buschur vs greedy and the buschur made 20more whp.go to dynoflash for the vid and see your self exhuast expert.
Old Jun 16, 2008 | 12:10 AM
  #63
IDRINKV8'S's Avatar
my friend had the buschur bullet catless tbe
Old Jun 16, 2008 | 12:13 AM
  #64
loud?
Old Jun 16, 2008 | 12:37 AM
  #65
hennessey01's Avatar
Most people would hate on the HKS exhaust but i really like it. Seeing how i only paid 800 for the turbo outlet, downpipe, testpipe, and the HKS exhaust, i couldn't pass that up.
Old Jun 16, 2008 | 12:48 AM
  #66
IDRINKV8'S's Avatar
Yes loud but in a really good way has a distint tone you have to hear one in person.My even made more power and crazy tq with buchur stage*****then people with cams upgraded intercooler piping,and o2 housing,maybe the most i seen on 93oct no meth.
Old Jun 16, 2008 | 01:51 PM
  #67
ElectricBlueIX's Avatar
If you don't mind it very loud then go for it either way they both sound sick just the br sound's more nasty and meaner good choice then.what other mod's have you done if you wan't advice??
At the moment I have a Tomei bov and a drop in K&N filter. I think I may have a reflash because the car will rev to 6k and act like it's anti-lagging. And a friend of mine had a evo 9 rs and he told me my car feels really strong for stock. I know people talk about if you do a hard intake pipe your gonna need to tune it cause the mass air sensor is so sensitive to that so do you think I should change out for just a cone filter or go with the full intake pipe? My plans are to do a TBE, a different intake, boost controller, fuel pump and a wideband. I've had a friend tell me about the ECU flash software but I'm a little skeptical of it. What do you think?
Old Jun 16, 2008 | 02:04 PM
  #68
IDRINKV8'S's Avatar
As far as the intake setup go's don't waste your money on the hardpipe intake tube,just get the filtert setup,upgrade the hardpipe when you get a bigger turbo.Now for flashing goes this is were the car makes all the power because it amx's at all the mods on the car and you will be able to raise boost up and hold better to redline.The stock boost on the evo 9 is about 20psi and tapers to 14 psi.With a good aggressive flash on 93 oct boost would be 23or 24psi and hold 21psi taper with a good m.b.c. i don't know any who does tuning in your area but if you don't make a wise choice for a mail in becuase there all different some are good ans some are not if you don't have a good tunner in your area i would recommend you to the best.
Old Jun 16, 2008 | 02:26 PM
  #69
I know an extremely good tuner. He owns a 90 Talon awd that holds the stock motor whp record lol. My other friend has a 2.3 6 bolt swapped 2G gsx and another friend with an evo 8. We tune our own cars cause we don't have an awd dyno that's conveniently close. We usually don't have time to make a 2 hour trip just to tune a car so we just use widebands and laptops to tune. I was thinking I would probably wait on the full intake for a bigger turbo.
What size are my stock injectors and how much boost on the stock turbo are they good for?
Also, what do you think about the ECU flash software where I can reflash the ecu myself along with the help of very knowledgeable friends?
Old Jun 16, 2008 | 02:39 PM
  #70
IDRINKV8'S's Avatar
The stock injecter's are about 580cc,the stock injecter's can feed nice amount of fuel as long as you get a bigger fuel pump.THE stock turbo on 93oct is good for 24psi to 25 psi before it's start's knocking,with alky it can boost to 28 psi safe with upgraded injecter's 680cc the stock turbo can boost 31 psi before it run's out of cfm's.I suggest go with mellon tuning for the do it your self tune.For the intake you can get just the filter now and tube later on.
Old Jun 16, 2008 | 02:44 PM
  #71
Thanks for all the info. I'm sure with 110 it can handle 28 psi correct? I didn't realize the stock turbo was good for that amount of boost. It seems like it would just be blowing hot air at that point, even with an upgraded front mount and piping.
I've heard of Mellon tuning and aren't they here in South Carolina?
Old Jun 16, 2008 | 02:56 PM
  #72
bboypuertoroc's Avatar
Veteran: Army
Here's my opinion on exhausts...
All the Evos out here run different exhausts. I've heard them all in every configuration (cat/no cat/high flow cat/stock cat/etc.). Out of all the exhausts I've heard, the Greddy Ti (not Ti C) sounds the best followed by the JIC Ti. After those, I'd say my TurboXS TBE sounds the ****. I bought it used a few years ago so maybe the muffler packing is just worn to **** or whatever, but it sounds better than every other non-ti exhaust I've ever heard. The Buschur TBE sounds a little too high-pitched compared to others (it's not as deep as some people say), but performs and fits better than the rest. The Megan sounds damn good for the price. The RS*R coupled with a DC Sports 2 in 1 is LOUD. The AMS exhaust has a great tone to it, but it sucks that you have to use their downpipe and their test pipe (unless you get 2 bolt flanges welded on). The HKS Carbon Ti looks great and sounds good, but performs the worst out of the 3 inch systems (mostly because it's not 100% 3 inch all the way through). The JIC with the ti muffler sounds damn good, almost as good as mine.
Old Jun 16, 2008 | 04:27 PM
  #73
Mellon Racing's Avatar
I'm in Memphis, TN area but also offer remote tuning options... see www.mellontuning.com
Old Jun 16, 2008 | 10:21 PM
  #74
That is one damn impressive evo you got there. Wow.
Old Jun 16, 2008 | 10:26 PM
  #75
Turbodemon's Avatar
hmm i was not talking serious there i was just showing love for what i got.
but i will look into that now that u mentioned it. just looks cheap to me with no flanges vbands are imo. if i want a vband exhaust ill buy a mustang.
