changing flat need help
ok so ive changed tires b4 on my civic but im having trouble removing the passenger front wheel off, i removed all 5 lug nuts but the wheel wont budge. must i remove the big nut inside the center cap? or am i missing something else? need help quick please
Yeah, kick it, wiggle it, make sure it's all the way off the ground etc etc. It should budge unless you have some weird aftermarket setup. All it is is the 5 lugs on the 5 studs.
How long did you drive on it while it was flat or really low pressure? You may have bent something...
You need a bigger hammer. There is nothing else holding the wheel on except the lugs. If you kicked it and it didn't move, kick it harder. If it's on pavement and you have a decent jack, lower the car with the lugs off and see if the weight of the car will pop it off.
Don't drop the car entirely down though as the wheel may come off and drop to the ground.
/brox
/brox
/brox
/brox
