Time for a new clutch.. need some input
Old Mar 21, 2009 | 09:00 PM
guapoholic's Avatar
I'm changing out the OEM mitsu clutch to an ACT streetlite clutch and debating between a ACT prolite/streetlite flywheel; 13.3 lbs vs 10 lbs fyi. I really need the clutch soon because my gears are slipping and grabbing at real high RPMs (bout 3.5 grand) Plus it just makes the car NO fun to drive at all
Is it imperative that I also change the pressure plate or will I be fine changing the flywheel, clutch disc and throw out bearing?
Old Mar 22, 2009 | 09:36 AM
McLaren F1 2003's Avatar
change out the pressure plate also (buy the entire ACT kit, if thats what you want) and youll be fine with the streetlite flywheel
Old Mar 22, 2009 | 07:25 PM
guapoholic's Avatar
I really can't stand to drive the car with the clutch in it's current condition and money is an issue right now so I've decided to just get the clutch and get that installed for the time being. ACT recommends changing the flywheel as well. Is that necessary?
Old Mar 22, 2009 | 07:44 PM
just make sure the stock flywheel gets resurfaced...im running the ACT HDSS clutch kit on the stock flywheel right now, and its great
Old Apr 21, 2009 | 08:57 PM
killmall's Avatar
well when ur looking for clutch's it all depends on how much torque ur planning to put out cause clutch's are rated by torque ..... map out what ur plans are then decide on a clutch...
i had to find out the hard way....
