Need Some Help ASAP!
Old Oct 23, 2009 | 06:32 PM
MYEVOVIII's Avatar
Yes get it tuned asap. And in the mean time either turn down your boost or put back to stock.
Best of luck
Old Oct 24, 2009 | 12:57 PM
ZFRED10's Avatar
Turn down my boost with my MBC. Well I tried to. It's still max boostin' and cutting out.
Old Oct 25, 2009 | 09:39 AM
92gsxbaltimore's Avatar
then you have one of two problems:
1. your waste gate is stuck open.
2. your MBC is not connected correctly. Check the How To section for proper installation.
Old Oct 26, 2009 | 02:02 PM
ZFRED10's Avatar
Fixed. MBC was not correctly connected. Thanks for the input guys.
Old Oct 26, 2009 | 07:38 PM
NP, glad its working. Make sure you get a tune ASAP.
p.s. Still do yourself a favor and check your plugs.
Old Oct 30, 2009 | 08:20 AM
SBR INC's Avatar
92GSX is right, you need to check your plugs and see how they look. Plugs are so over looked, it's insane. It only takes a quick second to pull the out and check them.
Once you do, you'll probably find that they could use replacing. She'll run much better with a fresh set of plugs and something like the NGK BPR7ES are inexpensive and work great on the EVO VIII.
Good luck with the rest of the project!
