For some reason my 30r isnt making the power it should be making? help!!
Subscribe
Oct 10, 2009 | 11:37 AM
ok i just got this car about 5 months ago and it was already hooked up with performace parts. It has a r&r kit 30r with basic bolt ons and i really dont know what size are the injectors. i recently put 272 hks cams and got it street tuned....but for some reason it doesnt pull hard enough. The tune was great sounds good and boosts really good it just doesnt go. The only problem was that the air temp was bad it was around 130+ and i know thats not good at all. I was thinking maybe i know the problem but im not to sure. The upper piping is different then what i have seen and i really dont have room for a good air filter so i have to use a short one i have a k&n typhoon. My tunner said thats my problem air filter and to much heat sock. Please help this **** is driveing my crazy. o and by the way i raced my friend last night he has bolt ons and cams and 101 gas and he spanked me on the freeway!
Reply 0
Oct 10, 2009 | 01:15 PM
who is your tuner?
Reply 0
Oct 10, 2009 | 02:53 PM
the tuner works at a shop that specialize in evo instally and tunes..and he know how to tune hes done many.
Reply 0
Oct 10, 2009 | 03:03 PM
just curious..what shop is this?
I'd check out the size of those injectors, unless ur fuel mapping is appropriate. what is the air/fuel ratio because if ur running too lean, then the air intake could be a possibility.
Reply 0
Oct 10, 2009 | 03:04 PM
also, give a full modification list, it will give us a better view and maybe narrow down an issue.
Reply 0
Oct 10, 2009 | 03:22 PM
well the tuner guy use to work for road race and tuning teck in socal....and for my mods.. precision r&r turbo kit, icp all custum, ams ic, typhoon intake filter, custom downpipe 3", hks hi power exhaust, 3" test pipe, precision injectors dont know what size r they? 272 hks cams
Reply 0
Oct 10, 2009 | 03:40 PM
Quote: the tuner works at a shop that specialize in evo instally and tunes..and he know how to tune hes done many.
I'll ask again
who is he?
Reply 0
Oct 10, 2009 | 03:55 PM
some guy name jc
Reply 0
Oct 10, 2009 | 04:37 PM
u will need a 255 fp
Reply 0
Oct 10, 2009 | 05:14 PM
i have a walbro fuel pump forgot to mention that my bad
Reply 0
Oct 10, 2009 | 07:07 PM
do a compression cheack on the motor.. maybe ur motor is tired
Reply 0
Oct 13, 2009 | 07:29 PM
i will defanitly check the compession on the motor im hopeing its not bad..the motor only has 28 k miles on it
Reply 0
Oct 14, 2009 | 10:49 AM
compression check and boost leak check. also if it is the tune you're worrying about, check out the tuners here. they are excellent
Reply 0
Oct 14, 2009 | 10:50 AM
Only thing i notice off the bat is that its an RnR kit and every car i have come in contact with that had that kit NEVER makes the power it should..
Mike
Reply 0
Oct 14, 2009 | 12:01 PM
If your compression and boost leak tests are good then run it on a dyno and sheets for afr, boost, and power. That way you'll at least have some solid numbers to troubleshoot from. Your tuner might be sharp but without all of the tools he might not be giving you the best possible advice.
Reply 0
