Dumb Gas question
Old Jun 6, 2010 | 07:21 AM
thedru13's Avatar
Dumb Gas question
Ok I noticed this at the pump the other day and was curious... When I unscrew the gas cap .. Where you put the gas pump has no flapper thing inside. So the whole is open. Not sure if that normal or not. On my other cars they are closed until you put the nozzle in. I know its a silly question but my gas mileage is just gawd awful so reaching at straws..
Old Jun 6, 2010 | 07:28 AM
wizzo 8's Avatar
Normal.
Old Jun 6, 2010 | 07:32 AM
Bggstin's Avatar
Do you have stock plugs in the car/have you changed them at all?
Old Jun 6, 2010 | 10:12 AM
Jamesm331's Avatar
How many miles are you getting to the gallon?
Old Jun 6, 2010 | 10:30 AM
thedru13's Avatar
I have stock plugs changed them about 2k miles ago. I get just about 200 miles on a full tank and is not really changed if I am highway or City. I am on the stock snail with stock injectors as well as stock fuel pump.
Old Jun 6, 2010 | 10:44 AM
Zdrummer15's Avatar
Well you should definitely be getting more then 200 miles out of a tank.
Old Jun 6, 2010 | 10:45 AM
Jamesm331's Avatar
do you boost like its your job lol
Old Jun 6, 2010 | 10:48 AM
thedru13's Avatar
LOL.. I do enjoy the boost... Example was on the highway this weekend. Fresh tank of gas. 70 miles in and I was down to half a tank just a bit above. So City/Highway boost or not boost has not effected it to to much..
Old Jun 6, 2010 | 12:37 PM
Zdrummer15's Avatar
Whether you are boosting constantly or not, you should be able to get more then 200 miles on average. Are you sure you're actually driving your car until it's empty. It sounds dumb, but I know of a few people including myself that have always filled up their cars when they got to E and never really thought about the fact that they were putting in 4 gallons less then the tank holds.
Old Jun 6, 2010 | 12:39 PM
thedru13's Avatar
I wait till the gas light is on.... And needle is like pinned on E..
Old Jun 6, 2010 | 08:19 PM
Zdrummer15's Avatar
Well I'm saying it's possible your gas gauge could be off. How many gallons do you put in at that point to fill it up?
Old Jun 7, 2010 | 07:19 PM
DeeezNuuuts83's Avatar
If you're struggling to hit 200 miles on a full tank, then something could be wrong. That calculates to somewhere around 16 mpg, which is pretty terrible under the assumption that you're just doing typical daily driving. My IX typically gets somewhere between 19-20 mpg on the daily grind (it's bone stock with the exception of the OEM-sized Z1 Star Specs, though on the old OEM Advans my daily driving mpg seemed a hair higher, usually between 20-21 mpg), though the worst that I have seen in daily driving was just about 18 mpg, though this past weekend I hit 30.399 mpg, which is my all-time best.
Old Jun 7, 2010 | 07:25 PM
lucky_evo's Avatar
mix of city / hwy and around 225.......
goldenEvo's Avatar
I get around 19-24. Double check how many gallons is actually going in.
Old Jun 7, 2010 | 10:02 PM
white_evo27's Avatar
+1... even with 330whp (cams, etc..) im still gettin 280-300 miles per tank... possible boost leak?
