brake light keeps coming on and off
Old Jul 26, 2010 | 07:44 PM
shrty10135's Avatar
I just noticed when im driving the brake light keeps coming on and off, it goes off at lower speeeds but when u downshift and the engine revs up it comes on and when your cruising at like 65 70 it stays on and goes off when you slow down, obvioulsy i checked the brake handle hahah, it also comes on when you booost hard (pretty ironic that when you step on the gas hard it comes on hahha)
Old Jul 27, 2010 | 05:25 AM
shrty10135's Avatar
bump
Old Jul 27, 2010 | 05:37 AM
gsrboi80's Avatar
If you are low on brake fluid in the MC the light will come on.
That said check your brake pads as they wear it takes more fluid to compress the pistons hence the level in the MC goes down more triggering the light
Old Jul 27, 2010 | 05:38 AM
shrty10135's Avatar
triggers the e brake light?
gsrboi80's Avatar
Yes sir
Old Jul 27, 2010 | 05:39 AM
rcheung's Avatar
There is no light just for the ebrake. The light is for the ebrake switch in addition to low fluid in the master cylinder.
Old Jul 27, 2010 | 05:43 AM
shrty10135's Avatar
This is why i love you guys, sure enough the brake fluid is on the min mark, i thought there was like a sensor for the ebrake handle that was going. THANKS SO MUCH. now what brake fluid should i use? can i use one from autozone if so which on?
Old Jul 27, 2010 | 05:47 AM
gsrboi80's Avatar
EVO calls for DOT3 or DOT4 Fluid. For topping off any will work
Old Jul 27, 2010 | 05:49 AM
shrty10135's Avatar
ok so idk what i have in there now if i have dot 3 in there now its still ok to use dot 4? and it dont matter which one right (is dot 3 better then dot 4) which would u recommend
Old Jul 27, 2010 | 06:04 AM
gsrboi80's Avatar
Yea they can be mixed for just topping it off no worries. I use Motul or ATE Super blue in my car and totally bleed the entire system once a year or so.
If your just looking to top it off and not bleed the entire system grab some Pennzoil DOT 3/4 and top it off
Old Jul 27, 2010 | 06:23 AM
Roberti22's Avatar
haha i had the same thing happen a while back and it was that my cap wasnt seated right in the resievor and i was like WTF...but yeah man these guys got you in the right direction just pop the hood and check it out
Old Jul 27, 2010 | 08:55 AM
shrty10135's Avatar
thank you all so much, fixed and didnt cost me that much thank god since yesterday i spent 800 on my car (new tires and new oil)
epremsoft
Lancer Troubleshooting
Jan 7, 2016 06:24 AM
stikillller
May 9, 2008 10:25 PM
AhmadHasib
Feb 24, 2008 05:19 PM
Girodisc Martin
Mar 7, 2007 09:50 PM
Sti THIS
Mar 1, 2007 10:50 AM
