fuel injector
It's very easy, but this has nothing to do with site feedback or suggestions. Moving to the newbie forum.
I know how to do it, but you'll probably leak fuel everywhere because I dont' know how to depressurize the fuel rail.
1. unclip the injectors (the wiring has plugs to each one)
2. unbolt the fuel rail (2 bolts)
3. pull the whole rail back an out (should take a tiny bit of muscle, but be gentle because you won't have a lot of room to work with the fuel lines still attached)
4. pull out the injectors from the rail.
5. put in the new injectors, put the rail back in place, bolt it back and plug the wiring harnesses back in.
Sharing what kind of car you have helps too, prettyboy. I can only assume it's that easy on the Evolution as wel.
If anyone can share how to depressurize the rail I'd appreciate the info for the future and I'm sure prettyboy could use it too.
Originally posted by prettyboy188
is there a real damage pontential in installing the injectors becuase i heard its easy to do just takes time
No real harm unless you somehow manage to damage an injector or spray fuel everywhere.
depressurize the fuel rail by removing the back seat and the little panel underneath. disconnect the wiring harness to the fuel pump(the only electrical looking thing there). start the engine and let it die naturally. you can try cranking it 1 or 2 more times to make sure there's no more fuel in the rail. there will still be some left so have a few rags. then unscrew your fuel cap. and voila! depressurized fuel system.
and a link for those of you concerned just cuz i dont own an evo.
http://www.evomoto.com/popup_image_t...pN=walbro4.jpg
Isn't that a little um...dangerous for your engine letting it run out of fuel? Or will it just die quickly rather than gradually lean?
Mine seemed to have very little pressure in the rail and I did not depressurize. From what I've read that means I'm taking out the fuel pump too because I may have a bad check valve.
no, its good. learned it in class, read it in books. it's safe. gas just stops being delivered. spark and no gas won't do you any harm. if you don't want to go through all that, just take off the fuel cap. there'll be more gas in the system, but will stop pouring out sooner than if you didn't.
Gsxfury
17
Apr 24, 2008 10:44 AM
