Quick tire pressure question
Old Apr 1, 2011 | 12:12 PM
DeeezNuuuts83's Avatar
Is there a point where too much tire pressure (within reason) will have a negative effect on mpg? I remember some people mentioning that going a bit above what the sticker recommends can help, but I figured I'd ask, even though the answer is probably yes.
My mpg had taken a slight drop (nothing huge but enough for me to notice) maybe a month ago even though my driving is generally consistent along. I couldn't really think of what had changed, though I realized that I did adjust the tire pressure, and it may have been on a hot day when it happened. So when I checked it at my next fill-up, it was 38 front and 35 rear, so I lowered it a tad and I've noticed that things are a bit better so far compared to before. So I suppose I have my answer (and I'll be able to verify it over the next tank or two), but I was curious if anyone knew for sure or if they had personal experience with a certain psi being the maximum before things deteriorate.
Just to throw it out there, I have a bone stock Evo IX SE still on the stock BBS wheels but with stock-sized Z1 Star Specs with 14k miles on them (but still a good amount of meat left), if that matters. Thanks ahead of time. And no, this is not an April Fools question.
Old Apr 1, 2011 | 12:47 PM
fantrman's Avatar
To answer your question, no. More pressure = less rolling resistance = more MPG. However, consider the drawbacks with too much pressure - less traction, firm ride, uneven tire wear, unbalanced handling. Stick with the manufacturer's tire pressure recommendation label on the driver's door jamb (unless autocrossing or drag racing).
Old Apr 1, 2011 | 12:52 PM
Hmm... well I guess I'll figure out if I'm just being optimistic or if I'm really noticing better mileage after a couple of tanks.
I know that 32/29 is recommended (if I remember correctly), but even when I had the stock A046s I had always gone with 34-36 front/31-33 rear.
Thanks for the reply.
