Why does the evo bog when launching?
Old Apr 28, 2013 | 01:36 PM
Falltroy's Avatar
I searched and couldn't find an answer. As the title states, why can't the evo launch without bogging down. I know I could learn to dump the clutch, but I don't want to damage the drivetrain or clutch. Just curious now. Does it have something to do with it being awd?
Old Apr 28, 2013 | 01:45 PM
Robevo RS's Avatar
if you do it right it doesn't. you need to slip little bit the clutch , but there is a long thread about this, i think in the motorsport section below.
Old Apr 28, 2013 | 01:55 PM
GetterDragun's Avatar
Yes, there are a lot of pieces that need to move to get teh car going. Just read about this in a driveshaft thread. Seems lowering the rotating mass improves this. Aftermarket driveshafts save about 15lbs of rotating mass.
Old Apr 28, 2013 | 02:42 PM
Mr. Move's Avatar
Mine's never bogged only spun. lulz
Old Apr 28, 2013 | 02:52 PM
SaulHudson's Avatar
Thats why it bogs, if a awd clutch is dumped it will fall on its face, awd must be slipped.
Old Apr 28, 2013 | 03:18 PM
meckert's Avatar
A zillion reasons, any car that bogs is falling out of its torque band plain and simple--fix that issue and you are good to go. AWD is a major factor, split 400 ft ibs/tq by 4 and you get 100 ft ibs per wheel--not much---think about an old sentra with a 1 leg diff--about the same, no matter what it is you do you are limited in spinning that tire--. Same with the evo, all principles apply. Build and tune your car for a flatter torq curve lower in the rpm band and that helps. Built it for all out hp at 8k and unless you can solve the issue of falling out of torque band--then its going to bog.
Old Apr 28, 2013 | 05:07 PM
Falltroy's Avatar
Thanks- I get tuned next week and ill see what they can do with getting more torque at low rpms.
Old Apr 29, 2013 | 06:47 AM
Jake.barratt's Avatar
Slipppp the clutch.
Old Apr 30, 2013 | 12:19 AM
mirkendargen's Avatar
Basically, something has to give or the car will bog. That could be the car shooting forward like a rocket, the tires spinning, or the clutch slipping. If none of those things happen, the engine is hitting a brick wall and can't turn fast enough, and as previously stated if the engine can't turn fast enough, you don't get power.
Unless you have a lot of power, the clutch needs to slip. If you have a lot of power, the tires can spin. If you have a lot of power and slicks, the car shoots forward like a rocket....or something breaks
Old May 2, 2013 | 05:40 AM
denlin68's Avatar
remove clutch delay pill so you wont burn too much clutch when u slip ur clutch
Old May 21, 2013 | 07:27 AM
jt8217's Avatar
Give it MOAR GAS!
Old May 30, 2013 | 01:49 PM
arreola_2007's Avatar
Drove and MR for two years launched once in my new GSR and it fell on its face lol I had forgot how to launch an evo lol nailed it the second time tho
Old May 30, 2013 | 05:57 PM
0mega's Avatar
Give it the slip.
Old May 30, 2013 | 07:01 PM
hiboost2.0's Avatar
Originally Posted by 0mega
Give it the slip.
+1 or launch higher
Old May 30, 2013 | 07:23 PM
tellme718's Avatar
Because. 2 liter.
