Question from 2003: What is the best turbo for the Evo 7 8 9?
Old Sep 9, 2014 | 08:57 PM
mivec_chemist's Avatar
Hey guys,
I'm new here... I have had my Evo for almost two years now. I’m considering upgrading from my JB FP Green turbo. I just need 450-500hp . I’m looking for a turbo that spools quickly and can give me that power and great for daily commute.
My current setup is:
2.0 Built Motor
Wiseco Pistons 9.0:1
850cc Injectors
Manley Rods
ACL Bearing
ARP Head Studs
Manley Spring and Retainers
Kelford 272 Cams
AEM Cam Gears
Fluid Damper
DC Sports Tubular Manifold
Full 3” Exhaust Magnaflow System
Skunk2 68mm Throttle Body
AEM ECU
XS Power Aftermarket Intercooler
K&N High Airflow Intake System
Any information is welcomed. I'm looking at the FP Black MAP EF4 and GTX3076R... if there are better options feel free to assist. Thanks guys.:thumb up:
Old Sep 10, 2014 | 04:05 AM
tsitalon1's Avatar
What fuel?
Possibly a BB Red or 3BK... Not sure your injectors are going to cut it.
Old Sep 10, 2014 | 04:26 AM
90 octane... I should get like 1000cc???
Old Sep 10, 2014 | 04:51 AM
tsitalon1's Avatar
Is going to be very tough to reach your power targets on 90 octane!
You can reach 450whp with the turbo you currently have if you switch to e85.
I'd go to 1100cc injectors minimum.
A 3BK with e85 should easily reach 450whp.... might get 400-425 on 90 octane.
Honestly, before you spend any money, I'd contact Tom for an e-tune to see what he can do for you.
Old Sep 10, 2014 | 06:02 AM
Bhsj13's Avatar
that green is a great turbo. it will spool faster than the choices you posted.
Old Sep 10, 2014 | 06:29 AM
e_kobz's Avatar
I would stick with that you have. The FP Green spools pretty quick to begin with, all the other choices you mentioned will have significant more lag. If 90 octane is all you're limited by then you stuck between a rock and a hard place so to speak. The FP Green you currently have will have quick spool and generate that "uuuumph" you say you want, but it won't get you to 450-500whp. Going bigger to a FP a Black, MAP EF4, or any of the Garrett or Precision offerings will get you to meet your 450-500whp goal but will not have the "uuuumph" factor as much as the green does. Like I said earlier just stick with what you have. Quick spool and torque is more fun on the street.
Old Sep 10, 2014 | 06:32 AM
EatSleepBoost's Avatar
I would think you could get there with the green however as stated before that 90 octane is holding you back. How much psi are your running? What fuel pump do you have? With bigger injectors and a good fuel pump setup you may be able to make more power. What do you make now? You may need meth if you cannot find a better fuel solution to make that power. Most people in the US run 93 octane or E85, both of which are much better than your 90 octane.
Old Sep 10, 2014 | 11:46 AM
tsitalon1's Avatar
You might be able to achieve both with the FP Green, 90 octane, and meth.
Just a thought.
Old Sep 10, 2014 | 11:57 AM
kaj's Avatar
kaj
i've been running a MAP ef2.5 and love it.
or, according to a guy here in my town, you can make 450whp on e85 and a stock IX turbo. .....
Old Sep 10, 2014 | 12:08 PM
e_kobz's Avatar
Aaron from ER just 425whp with a stock turbo, bolt-on Evo IX with S2's, pretty damn impressive
Old Sep 10, 2014 | 02:49 PM
Hey guys!!! thanks a mil for all the info. @EATSLEEPBOOST thanks man... currently i have in the 255psi Walbro Fuel Pump... I'm making 345whp now... and out here i'm stuck with 90 octane... oh well thanks guys...
Old Sep 10, 2014 | 02:58 PM
tsitalon1's Avatar
Better fuel, e85, or meth. ... about the only way to get what you are looking for.
i just got the car... did an overhaul with all the new specs... so i'm gonna dyne and let you guys know how it goes... thanks again.
Old Sep 10, 2014 | 03:22 PM
kaj's Avatar
kaj
sounds like methanol is your best bet. good luck no matter what you choose!
Old Sep 10, 2014 | 04:25 PM
AlaskaZero's Avatar
An gtx3071 with an 0.82 A/R hotside could give you 500whp with E85/meth injection. Great for DD use as well....if your interested.
