Help! I don't know how to drive!
Old Jul 7, 2016 | 03:46 PM
Evo_9ssl's Avatar
Need help guys, im new here, My evo 9 having this isseu, when i press in the clutch under boost the rpm shoot up to red line, it only happining on wot, when your at 5000k or higer, my mods are exhaust manifold, o2 dump, 3"down pipe with hfc, hks ssqv4 bov, prerrin intake, ets fmic kit, grim speed boost controler, any body had this issue? thank you in advance
Old Jul 8, 2016 | 05:01 AM
desmvp's Avatar
Is your bov working correctly? I ask because if you have no drive train pressure and you still have boost going to the engine that would cause your issue. Just a guess.
Old Jul 8, 2016 | 07:54 AM
Evo_9ssl's Avatar
Ok, ill try to swap a stock bov, to see what will happen, thanks for the reply
Old Jul 8, 2016 | 01:42 PM
Epyon's Avatar
Wait, are you saying you just push in the clutch while full throttle and boost? Obviously if you push in the clutch while your acclerating with the gas pedal, your rpms are going to shoot up....
Old Jul 8, 2016 | 02:38 PM
Pal215's Avatar
Not sure if this is a serious thread.
Old Jul 8, 2016 | 05:16 PM
Evo_9ssl's Avatar
Ok, let say im on 2nd or 3rd gear, if i push in the clutch pedal, without pressing the gas, the rpm hoot up to red line, Only happen on high rpm 5000rpm or more.
Old Jul 8, 2016 | 05:42 PM
Bhsj13's Avatar
sticky throttle plate?
Old Jul 10, 2016 | 09:00 PM
Nathan Benoit's Avatar
Is this a troll thread? I imagine your mashing the gas then slamming your clutch to the floor. do this 10x and boom lol.
Old Jul 11, 2016 | 05:41 AM
Speedlimit's Avatar
Admin Emeritus
Hi,
Ask a friend who drives a stick shift to drive your car. It the RPM shoots up when he/she is driving while shifting, have a competent mechanic check out your car. You do not what to drive the car for long if you are challenging the RPM limiter on every shift.
Bob
Old Jul 11, 2016 | 09:15 AM
Evo_9ssl's Avatar
Originally Posted by Speedlimit
Hi,
Bob
It only hapening on higher rpm, around 5000rpm and up, did a boost leak test and found the injector seals are leaking, i will fix the leaks and im going to clean the throtle body as well, see what will happen, this isssue never happen to anyone here recently? Thanks guys for the reply
Old Jul 11, 2016 | 02:39 PM
josef344's Avatar
Never happened to me, when I first drove a stick back a while back I could never bang gears really good and ended up gassing it and pressing the clutch at the same time and ended up red lining it.
Thank god it wasn't an evo lol.
Old Jul 11, 2016 | 05:24 PM
Evo_9ssl's Avatar
Yah! this is not a driving issue, i own two evos and my 03 evo 8 never had this problem!
Old Jul 15, 2016 | 11:26 PM
gray-fox's Avatar
lol are you sure your clutch isn't slipping?
Old Jul 16, 2016 | 09:13 PM
Evo_9ssl's Avatar
Yes, the clutch was just done 5000 miles ago so it should be good, its started happening when i got my tune, my tuner told me check for vacuum leaks found two vaccum hoses was off from the intake manifold, plug those hoses in and fix the boost leaks from the injector seals but nothing happen.
JARVEVO8
Jul 19, 2013 07:37 AM
Mr. Roman
Dec 9, 2011 12:23 AM
Evo_Jay
Feb 24, 2008 02:35 PM
