Making a High Flow Cat into Test Pipe??
Old Sep 29, 2008 | 09:33 AM
PedroMartinez's Avatar
I have a buschur HFC but i want to punch everthing out to make it a TRUE test pipe. I dont want to but a test pipe and me having to be taking it off each year to pass My NC state emissions. Anyone know how to punch the stuff out of these High Flow Cats?
Old Sep 29, 2008 | 12:43 PM
IDRINKV8'S's Avatar
U really want to do that to a buschur hi flo cat,just use the stock one with different flange's welded on.Anyway for you to gut it out is very easy put a straight pipe that's fit's inside the whole cat then smash it through using a hammer turn upside down and shake everything out and whalla cutted cat.
Old Sep 29, 2008 | 12:56 PM
madmax199's Avatar
Usually a big screwdriver is the weapon of choice for gutting a cat.
Old Sep 29, 2008 | 01:02 PM
MaxKanisha's Avatar
I heard gutting a cat still doesnt measure up to an actual TP, is that true?
Old Sep 29, 2008 | 01:26 PM
dgoodhue's Avatar
Yes, that is true. A hollowed cat is going to create disturbance in the exhuast flow vs a straight test pipe.
Old Sep 29, 2008 | 01:55 PM
MaxKanisha's Avatar
Is that what happens with resonated test pipes as well?
Old Sep 29, 2008 | 06:32 PM
EatSleepBoost's Avatar
i took a test pipe and welded the stock cat's heat shield around the test pipe. WORKS GREAT, flows even better
Old Sep 29, 2008 | 06:51 PM
MaxKanisha's Avatar
I heard the two stock cat heat shields were different.. Which heat shield did you use?
Old Sep 29, 2008 | 06:58 PM
i am not sure what u mean by that however i just cut the welds off the stock cat to remove the shield. matched it up on my test pipe in the postion i wanted it. did some slight bending adn tach welded it to the test pipe. it fit pretty good. you do have to elongate the ends slightly since the test pipe is 3".
not sure if i answered ur question but i used all of the stock heat shield pieces that removed from the stock cat.
Old Sep 29, 2008 | 07:01 PM
MaxKanisha's Avatar
Oh I see.. Did you use a stock VIII or stock IX cat heat shield?
Old Sep 29, 2008 | 07:39 PM
right off my stock 8 cat.
Old Sep 29, 2008 | 07:42 PM
pics are worth 1000 words. here you go.
Attached Thumbnails Making a High Flow Cat into Test Pipe??-adeaecge.jpg   Making a High Flow Cat into Test Pipe??-ayterytyy.jpg   Making a High Flow Cat into Test Pipe??-cattt.jpg   Making a High Flow Cat into Test Pipe??-hfcc.jpg
Old Sep 30, 2008 | 08:46 AM
MaxKanisha's Avatar
There is no 02 bung on the VIII heat shield right?
Old Sep 30, 2008 | 11:53 AM
right.
Old Sep 30, 2008 | 01:09 PM
dgoodhue's Avatar
I would imagine it depends on the construction, if the resonators are like the racing and straight through mufflers I have seen, then their is going to be minimal losses and flow restictions.
