EvoM Tuner Technical Debate Forum This forum will only allow threads and posts by tuners. This is for technical discussions only.
Post your Comp cam idle videos 272 if possible
Old May 10, 2006 | 08:50 PM
BoostWhore's Avatar
Lets see what some cars are idling like with the comp cams. Post your videos and let us know if your on stock ecu who flashed it etc and if you have cam gears and what there set to thanks. If you have dynos post them as well
Old May 11, 2006 | 05:59 AM
BoostWhore's Avatar
anyone?
Old May 11, 2006 | 06:12 AM
ibanez_926's Avatar
There is a video floatin around here of some 280's idleing. Search and i am sure you will find it.
They are pretty choppy, but its livable
Old May 11, 2006 | 06:24 AM
evoone's Avatar
Thumbs up
i like that choppy hotrod sound. i want to know if its true those cams come to life early.
Old May 11, 2006 | 06:35 AM
hotrod2448's Avatar
I've got the comp 272's but, no video. They idle fine. A bit of a lope to them but, not enough to stall out. You can definitely tell there is a more agressive cam in there. I'm also running them at -2/-2 so if you go straight up they may get a little more rough.
As far as power goes spool time seems to be about the same maybe a little better but, my god does it feel strong through the midrange and top end. Suprisingly it even feels better just off idle. Generally stronger all the way around but, most noticable up top where the factory cams run out.
Old May 11, 2006 | 09:27 AM
kingkyle's Avatar
you can hear mine right before i start my timed runs here
http://video.google.com/videoplay?do...897163&pl=true
Old May 11, 2006 | 09:37 AM
Miralution's Avatar
that sounds nice man. i like the idle being rough like that.
Old May 11, 2006 | 09:41 PM
BoostWhore's Avatar
anyone think its worth going from gsc 264s to comp 272s
