Exedy Clutch For Evo X @ Mellon Tuning
Check out the cluth kits for the Evo X, we have them here at Mellon Tuning Store...
Evo X Exedy Twin Plate Cerametallic Clutch Kit (Standard)
For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Number of Discs: Twin
Spring Damper Discs: SPRUNG CENTER DISC
Push / Pull: PULL TYPE
Disc Outer Diameter: 200mm
Spline Teeth / Major Diameter: 23T / 26.4mm
www.mellontuning.com/index.php?main_page=product_info&cPath=18_43&produ cts_id=367
Evo X Exedy Twin Plate Cerametallic Clutch Kit (Heavy Duty)
www.mellontuning.com/index.php?main_page=product_info&cPath=18_43&produ cts_id=368
Evo X Exedy Triple Plate Cerametallic Clutch Kit (Heavy Duty)
For high-powered applications, EXEDY offers triple Multi-Plate Clutches. These are designed for hot street action as well as drag, road and rally racing. The triple plate clutches are rated for up to and over 1000hp (for drag race applications) and triples are all solid discs. All of our multi-plate clutches come with a lightweight, chrome moly steel flywheel and the famous purple anodized forged aluminum clutch cover. Depending on the application, we have both strap drive and lug drive models.
All have T5001 cerametallic friction materials for extreme heat resistance. Engine modifications e.g.. cam-timing-turbo modifications etc. cause engine pulsation and vibrations. These vibrations can cause clutch rattle when the clutch pedal is depressed by movement on the intermediate separator plate in some applications. These noises will in no way affect the performance of the Exedy Multi Plate Clutch. This rattle is well accepted in the performance industry where engine modifications have been carried out.
www.mellontuning.com/index.php?main_page=product_info&cPath=18_43&produ cts_id=369
Evo X Exedy Twin Plate Cerametallic Clutch Kit (Standard)For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Evo X Exedy Twin Plate Cerametallic Clutch Kit (Heavy Duty)For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Evo X Exedy Triple Plate Cerametallic Clutch Kit (Heavy Duty)For high-powered applications, EXEDY offers triple Multi-Plate Clutches. These are designed for hot street action as well as drag, road and rally racing. The triple plate clutches are rated for up to and over 1000hp (for drag race applications) and triples are all solid discs. All of our multi-plate clutches come with a lightweight, chrome moly steel flywheel and the famous purple anodized forged aluminum clutch cover. Depending on the application, we have both strap drive and lug drive models.
