South Side Performance - X MR Transmission cooler/ 500whp transmission package
South Side Performance - Exedy Clutch Package - MR Trans cooler - Pro Gold SST Fluid
South Side Performance Transmission Cooler
The SSP PRO SERIES TRANSMISSION COOLER takes roughly 4 hours to install. Everything you need to go racing is included and is guaranteed to keep your transmission cooler than any other on the market.
$ 950.00
Kit includes the following:
- High flow dual pass 6x16" oil cooler
- Single high flow 6" fan with shroud
- High flow 2.5 gpm oil pump -6 AN high quality oil hose - Complete wiring harness
- Heavy duty toggle switch
- Heavy duty fuse holder
- 2 Banjo fittings
- 2 90 degree - 6AN fittings
- 2 -6AN straight fittings
- Assortment self tapping screws, and hardware.
Tried and tested on our 500+ whp X MR at VIR, Englishtown NJ, NJMP, Summit Point. Highest temps I've ever seen since running the front mount are 161 degrees (Fahrenheit) and that was on the Hottest day recorded at VIR since 1932. Ambient Temps were 105 degrees, and track temps were over 130! Never once did I get the dreaded "slow down warning" If you're looking for the best X MR cooler on the market look no further.
South Side Performance EVO X Engine Oil Cooler
SPECIAL INTRODUCTORY PRICE- 499.00
SSP IS PROUD TO ANNOUNCE THE RELEASE OF OUR NEW EVO X ENGINE OIL COOLER. TRACK TESTED, AND PROVEN TO DROP ENGINE OIL TEMPS BY AS MUCH AS 30+ DEGREES. WE USE A TOP OF THE LINE, DUAL PASS COOLER, CUSTOM FITTINGS, AND HIGH PRESSURE BRAIDED LINES.
FITS (2008-2011 GSR, RALLIART, MR)
SSP is now offering a blowout deal on Exedy Clutch and V3 Master Cylinders. For those looking to get everything at once for a great price, look no further !
EXEDY cerametallic clutches are designed to handle the abuse of high power modified engines. The cerametallic friction material can handle more abuse than a stock type disc, without the slipping and fading. All EXEDY Stage 2 cerametallic clutch discs have sprung center dampers to reduce the impact and shock loads transmitted through the drive-train.
SSP V3 Clutch Master Cylinder Upgrade
The Upgraded V3 CMC uses a newly designed Delrin lining/sleeve, which is a very hard, brake fluid resistant plastic which has nearly no friction with the rubber seals. This will allow the CMC to have a smoother pedal engagement, while extending the life of clutch piston seals. Another major upgrade is the longer body design, which allows for all types of pedal height adjustments, while keeping the spring from bottoming out.
*Exedy Organic Stage 1 Clutch Kit (Mitsubishi Evo X) - $426.38
*Exedy Organic Stage 1 HD Clutch Kit (Mitsubishi Evo X) - $469.02
*Exedy Cerametallic Stage 2 Clutch Kit (Mitsubishi Evo X) - $581.78
*Exedy Cerametallic Stage 2 HD Clutch Kit (Mitsubishi Evo X) - $640.05
*Exedy Cerametallic Stage 4 twin plate Clutch Kit (Mitsubishi Evo - $1,655.95
*Exedy Stage 2HD/SSP MC3 COMBO SPECIAL - $978.00
*EXEDY STAGE 4 TWIN PLATE /SSP MC3 COMBO SPECIAL - $1,999.00
In stock and ready to ship !!
$ 950.00
- 2 Banjo fittings
Exedy Stage II + V3 CMC - $938.00 +shipping
(TQ Capacity - 366 ft/lbs)
Exedy Stage II HD + V3 CMC $978.00 +shipping
(TQ Capacity - 437 ft/lbs)
