HBSpeed stealth stage HP package!!!!
We have a little stealth package going for you Evo X guys who are interested in gaining a good amount of extra HP but still want to look/sound stock..This PKG also leaves you open for future modifications if you decide you catch the HP bug
The PKG includes the Cobb AP/Boost pill with a custom dyno tuned map for your car/If you are out of state we have a base map we can send you as well for a lower price (minus the boost pill)!
Flashing the ECU for increased performance is just the start of what the AccessPORT is capable of. Set the AccessPORT to Performance mode to capture 0-60MPH times, ¼ Mile times and Trap Speeds. Switch over to Live Data and choose a gauge to monitor, such as; coolant temperature, intake air temperature, throttle position, intake cam advance, exhaust cam retard, MAF voltage, injector pulse width and many more. Select the integrated Datalogger to record multiple channels of data simultaneously. Or use it as a shift light that flashes the screen when a user defined rpm is reached. Use the Troubleshooting mode to diagnose issues by reading the factory codes and resetting the system once the issues have been resolved.
The AccessPORT can be used to eliminate separation anxiety for those times you are away from your car. Protect your investment when out on the town by quickly loading the Valet map to prevent the engine from revving above 3,200 rpm. Load the Anti-Theft map when you park to make it impossible to start. And in the event the car must be returned to the stock configuration, the AccessPORT can be completely removed and the ECU restored to its factory condition.
AccessTUNER Pro for the EVO X is available to the COBB Pro Tuner network. AccessTUNER Pro allows professional engine tuners to custom tune any combination of modifications to achieve their maximum power potential. AccessTUNER Race for the EVO X is available to racing teams and highly experienced self tuners. AccessTUNER Race allows individuals the ability to tweak their own maps files at their convenience as well as the ability share maps with others that have very similar power modifications. Datalogging allows multiple channels of data to be recorded and reviewed after a dynamometer test to see where tuning can be optimized. These capabilities are particularly effective for heavily modified EVO X’s that are modified beyond the scope of the COBB Tuning provided base calibrations.
The AccessPORT from COBB Tuning is the most comprehensive hand-held ECU flashing, monitoring and managing device available for the Mitsubishi EVO X. Combined with AccessTUNER Pro and AccessTUNER Race software, it provides an unbeatable suite of engine tuning applications backed by our professional engine tuner network.
Satisfy your hunger for more power. Access the Potential of your EVO X today!
EVO X AccessPORT Features:
• Increase horsepower and torque with the touch of a button
• Easy installation requiring no tools or computer skills
• Display vehicle performance with 0-60MPH and 1/4 Mile clocks and Trap Speeds
• Monitor vehicle data such as MAF voltage, coolant temp, throttle position and much more.
• Built in Datalogging capability for multiple data channel recording.
• Troubleshoot by viewing trouble codes and resetting ECU.
• Valet and Anti-Theft modes help prevent abuse and theft
• Upgrade firmware and download calibrated maps over the internet
• Completely and easily uninstallable
AMS 02 housing downpipe
The AMS EVO X "Widemouth" downpipe is the most power producing and well designed downpipe on the market. After months of development and testing we have created the best flowing downpipe possible. Using a CAD designed cast o2 housing we were able to obtain every angle we wanted for perfect fitment and flow.
Our downpipe is completely made of 304 stainless steel including both flanges and includes a bung for a wideband gauge with a plug included.
Features
• Best flowing downpipe available, completely replaces o2 housing and downpipe
• 100% Stainless Steel construction. No mild steel flanges
• 15+ Wheel Horsepower gains over stock
• Bolts up to the factory catalytic converter
• Unrivaled fit and finish
Specifications
• 304 Stainless Steel
• 3” piping .049” wall thickness
• 3/8" Thick Stainless Steel flanges
And the AMS Hi flow cat!
The AMS 3" High-Flow Cat provides an excellent way to increase horsepower all while keeping you legal. Utilizing a steel core catalytic converter instead of the conventional ceramic core this piece is designed to stand up to extreme conditions and last!
Like all other AMS exhaust products this test pipe is TIG welded with 100% 304 stainless components including the flanges. Designed to bolt up to a stock exhaust system, AMS System or any other aftermarket exhaust compatible with stock downpipe or cat-back. By simply installing the AMS High-Flow Cat you can expect to see up to 12 Wheel Horsepower gains over the stock catalytic converter without even re-tuning the ECU!
Features
• 100% Stainless Steel construction. No mild steel flanges or hangers
• All flanged connections. No band clamps or slip fits to come loose
• Up to 12 Wheel Horsepower gains over the stock catalytic converter
• Steel core catalytic converter for long life under harsh conditions
• Bolts right in place of the factory catalytic converter
• Utilizes the factory bracket for the stock exhaust hanger
• Stainless Steel O2 sensor bung welded in the factory location
• Stainless Steel O2 sensor bung welded in for a wideband gauge
• Includes gaskets and hardware
Specifications
• 300 Cell count
And a Cosworth Hi/Dry flow drop in filter
Package price for parts, installed and tuned- $2125 (+tax if paying with credit card/no tax for out of state)
Note to out of state/Far away Evo guys- If you buy this package we can give you a discount (-$400 off the price) since you wont be getting any labor done and no dyno tuning.
We will send out a custom base map for the Accessport with these mods as well for you guys!
This will make your Evo X feel like a different car with Huge Hp/Tq gains
Look for around 310-335whp (on our dyno custom tuned) with this set up!
Features
Specifications
Features
Specifications
• 300 Cell count
Jhurley_EvoVIII
Sep 11, 2015 07:22 AM
evo_soul
Toronto Lancer Club
Apr 6, 2011 07:40 PM
Spun Autosports
EvoX 'For Sale' External Engine / Power
97
Nov 1, 2009 09:21 AM
SPOOLEDTSiAWD
For Sale - Cars For Sale
35
Nov 26, 2008 07:45 AM
