Power Mods for EVO X - IN STOCK & Ready to SHIP!!
Old Mar 11, 2010 | 09:35 AM
  #46
SniperwolF's Avatar
pm price men
Old Mar 11, 2010 | 09:45 AM
  #47
Vivid Racing's Avatar
PMs sent!
Thank you,
Jim
Old Mar 11, 2010 | 01:45 PM
  #48
evo 2008's Avatar
do you have a turboback with bung for wideband shipped 12919
thank
Old Mar 11, 2010 | 03:27 PM
  #49
PM sent.
Thank you,
Jim
Old Mar 11, 2010 | 04:03 PM
  #50
**Agency Power GT35R Twin Scroll Turbo Kit Mitsubishi EVO X 08+ **
** Agency Power GT35R Twin Scroll Turbo Kit Mitsubishi EVO X 08+ **
**PM me for special pricing!**
Installation (Optional): $1225.00 (Includes Motul Oil Change)
Dyno Tune: $350
Agency Power is proud to be the first in the world to release a complete Garrett bolt on turbo upgrade for the new Mitsubishi EVO X. This turbo upgrade features all the hard parts you need to take your EVO X to the next level.
The turbo kit features all made in the USA components which are a direct replacement for the OEM turbo parts. The hand made TIG welded header features a true merged collector for proper exhaust flow. The ½ inch thick stainless steel flange is CNC machined for a precise flush fit to the engine. From the header, we run twin Tial 44mm external wastegates with V-Band clamps that run dump tubes straight to the ground. Each dump tube features a flex joint and bracket for a secure fit as it shoots flames from the serious power. The kit features a new turbo suction pipe and upper intercooler pipe needed to match up to the twin scroll Garrett GT35R turbo. The intercooler pipe is a 2 piece unit with a bracket for a secure fit on the radiator support beam. The intercooler pipe fits to the stock or aftermarket front mount intercooler with the provided silicone coupler. This pipe is available in a polished finish. The turbo suction pipe is designed to mount up to the stock air intake system or the Agency Power short ram intake. It features the provisions for the blow off valve return, breather line, and boost fittings necessary like OEM. To keep the Garrett GT35R turbo cool, Agency Power supplies proper water and oil lines with fittings to bolt up to the factory locations.
The large GT35R twin scroll turbo mounts to the exhaust system by a V-Band clamp 3 inch downpipe. The downpipe has a flex joint to provide necessary room for movement as the engine flexes its massive power. The downpipe is designed to bolt up to the factory catalytic converter or our Agency Power Cat Delete Pipe. This twin scroll GT35R turbocharger provides the 2.0L engine with quick spool up and serious top end power. Based on the dyno sheets, you can see peak boost being achieved in the mid range RPM’s. That makes this kit a great daily driver and road racing turbo setup as well having the ability to run low 11 second quarter mile times.
With the sold separately Agency Power parts including a Front Mount Intercooler, Catback Exhaust, Cat Delete Pipe, Short Ram Intake, Upgraded Injectors, Upgraded Fuel Pump, and ECU Flash, this bolt on kit put down 510 horsepower on 91 octane at 20psi of boost and 600 horsepower on C16 race gas with stock internals. The C16 race gas map at 30psi of boost held a perfect air fuel reading. With further custom tuning, the addition of larger camshafts, and stronger head studs, this turbo kit will produce an easy 650-700 horsepower.
The Agency Power GT35R Twin Scroll Turbo Kit for the new Mitsubishi EVO X is available through authorized Agency Power EVO X parts distributors ONLY. The kit includes: 1 x Twin Scroll GT35R Turbo, 2 x Tial 44mm External Wastegates, Oil Lines w/Fittings, Water Lines w/Fittings, 1 x Twin Scroll Header, 2 x Wastegate Dump Tubes, 1 x 3 inch Downpipe, 1 x 2piece Upper Intercooler Pipe, 1 x Turbo Suction Pipe. For custom powdercoat colors of the intercooler pipe and turbo suction pipe, please contact --
Steve Waliszewski - Service Advisor
Performance and OEM Service & Repair
480-966-3040 Ext 240 Steve@vividracing.com
Toll Free- 1-866-44VIVID
Attached Thumbnails Power Mods for EVO X - IN STOCK & Ready to SHIP!!-apturbo-kit-1.jpg   Power Mods for EVO X - IN STOCK & Ready to SHIP!!-apturbo-kit-2.jpg   Power Mods for EVO X - IN STOCK & Ready to SHIP!!-ap-turbo-kit-dyno-sheet.jpg
Old Mar 15, 2010 | 01:24 PM
  #51
** Dyno Tune/ECU Reflash Any EVO @ Vivid Racing for $350 **
ECU Flash:
** Out of State? Mail us your ECU, we will flash it and mail it back **
Dyno Tune:
** Comes With Dyno Sheet Showing Horsepower and Torque Before and After Tune.
RE-Flash: $150
Vivid Racing has one of the most comprehensive tuning facilities in the Southwestern USA. We have tuned everything from street cars, race cars, trucks, and more. With our Mustang AWD Dyno, we get accurate before and after tests results showing the gain our tuning department can give you. Qualified and specialized in tuning tools such as the UTEC, Ecutek, Cobb Accessport, AEM, Softronic, Link Electro, Hydra, ApexI, Greddy, OCT Tuning, and many more. We have even an indepth capability to tune your diesel car or truck.
** We Can Change **
- Timing
- Boost
- A/F Ratio
- Idle
- MIVEC
- Speed Limiter/Rev Limiter
- Launch Control
- And More…
TOLL FREE: 1-866-44-VIVID
OFFICE HOURS:
Mon-Fri 9am-6pm
VIVID RACING
1429 W. Scott Ave.
Gilbert, AZ 85233
Attached Thumbnails Power Mods for EVO X - IN STOCK & Ready to SHIP!!-blueevo-dyno.jpg
Old Mar 15, 2010 | 05:48 PM
  #52
Night Bump
Old Mar 16, 2010 | 01:43 PM
  #53
Bump
Old Mar 16, 2010 | 05:49 PM
  #54
AMS Evo X Front Mount Intercooler **in stock and ready to ship!**
We have an Evo X front mount intercooler core in stock and ready to ship. The AMS replacement intercooler core is a direct bolt on, utilizing your stock piping hangers and mounting points with purpose built end tanks for the EVO X. This intercooler has over 80% more internal flow area than its stock counterpart.
All AMS intercoolers are pressure tested after assembly. This intercooler core upgrade adds 10 additional wheel horsepower on a stock Evo X!
**Please PM me for pricing**
Old Mar 18, 2010 | 09:30 PM
  #55
SniperwolF's Avatar
pm price turboxs cbe, turbo back, catless...
Old Mar 19, 2010 | 10:19 AM
  #56
PM sent.
Thank you,
Jim
Old Mar 22, 2010 | 11:17 AM
  #57
Bump
Old Mar 23, 2010 | 05:38 PM
  #58
Bump
Old Mar 24, 2010 | 01:43 PM
  #59
((((( Agency Power TurboBack Exhaust Special--EVO X 08+ )))))
((((( Agency Power TurboBack Exhaust Special )))))
** PM FOR SPECIAL PRICING **
Agency Power has released their production sample exhaust systems for the new Mitsubishi EVO X. This exhaust is currently being tested and reviewed by selected individuals in the market. Reviews, installation pictures, and more sound clips can be seen on different forums and blogs. The pre-production unit is all T304 stainless steel. The 3 inch piping includes high quality precision cut flanges for a perfect fit. Agency Power utilizes a dual pipe setup to deliver efficient exhaust flow and maximum power. The mufflers are a straight through design and feature 4 inch titanium tips. The system fits with factory hangers and can be used with the factory catalytic converter or our optional test pipe with O2 bung.
To make this a Turboback, also included is the Agency Power Downpipe and Cat Delete Pipe.
The all new Agency Power Mitsubishi EVO X downpipe is designed to fit the 2008 and up GSR and MR editions. The downpipe is full 3" stainless steel with thick flanges and includes the needed o2 sensor location. Adding this downpipe to your car will help your turbo spool faster increasing boost and horsepower. It will improve the exhaust flow that is needed on a turbo charged car. This Downpipe fits with the stock donut gasket and will connect to the stock catalytic converter or an Agency Power Cat Delete pipe.
The cat delete pipe is all T304 stainless steel featuring thick flanges. The 3 inch pipe has the spot for the factory O2 bung with the riser to avoid the check engine light. The cat delete test pipe fits with the stock or aftermarket exhaust.
480-966-3040 Ext 240 -- Steve@vividracing.com
Old Mar 25, 2010 | 10:53 AM
  #60
Bump
