Power Mods for EVO X - IN STOCK & Ready to SHIP!!
PM FOR SPECIAL PRICING
Agency Power is proud to be the first in the world to release a complete Garrett bolt on turbo upgrade for the new Mitsubishi EVO X. This turbo upgrade features all the hard parts you need to take your EVO X to the next level.
The turbo kit features all made in the USA components which are a direct replacement for the OEM turbo parts. The hand made TIG welded header features a true merged collector for proper exhaust flow. The ½ inch thick stainless steel flange is CNC machined for a precise flush fit to the engine. From the header, we run twin Tial 44mm external wastegates with V-Band clamps that run dump tubes straight to the ground. Each dump tube features a flex joint and bracket for a secure fit as it shoots flames from the serious power. The kit features a new turbo suction pipe and upper intercooler pipe needed to match up to the twin scroll Garrett GT35R turbo. The turbo is a custom Gt35r. With a Gt35R compressor side,and the exhaust side has a P- trim housing T4 flange with your choice of AR.70 or .84. This combo should produce 35-40 whp more than standard 35r due to larger exhaust housing.
The intercooler pipe is a 2 piece unit with a bracket for a secure fit on the radiator support beam. The intercooler pipe fits to the stock or aftermarket front mount intercooler with the provided silicone coupler. This pipe is available in a polished finish. The turbo suction pipe is designed to mount up to the stock air intake system or the Agency Power short ram intake. It features the provisions for the blow off valve return, breather line, and boost fittings necessary like OEM. To keep the Garrett GT35R turbo cool, Agency Power supplies proper water and oil lines with fittings to bolt up to the factory locations.
The large GT35R twin scroll turbo mounts to the exhaust system by a V-Band clamp 3 inch downpipe. The downpipe has a flex joint to provide necessary room for movement as the engine flexes its massive power. The downpipe is designed to bolt up to the factory catalytic converter or our Agency Power Cat Delete Pipe. This twin scroll GT35R turbocharger provides the 2.0L engine with quick spool up and serious top end power. Based on the dyno sheets, you can see peak boost being achieved in the mid range RPM’s. That makes this kit a great daily driver and road racing turbo setup as well having the ability to run low 11 second quarter mile times.
With the sold separately Agency Power parts including a Front Mount Intercooler, Catback Exhaust, Cat Delete Pipe, Short Ram Intake, Upgraded Injectors, Upgraded Fuel Pump, and ECU Flash, this bolt on kit put down 510 crank horsepower on 91 octane at 20psi of boost and 600 crank horsepower on C16 race gas with stock internals. The C16 race gas map at 30psi of boost held a perfect air fuel reading. With further custom tuning, the addition of larger camshafts, and stronger head studs, this turbo kit will produce an easy 650-700 horsepower.
The Agency Power GT35R Twin Scroll Turbo Kit for the new Mitsubishi EVO X is available through authorized Agency Power EVO X parts distributors ONLY. The kit includes: 1 x Twin Scroll GT35R Turbo, 2 x Tial 44mm External Wastegates, Oil Lines w/Fittings, Water Lines w/Fittings, 1 x Twin Scroll Header, 2 x Wastegate Dump Tubes, 1 x 3 inch Downpipe, 1 x 2piece Upper Intercooler Pipe, 1 x Turbo Suction Pipe. For custom powdercoat colors of the intercooler pipe and turbo suction pipe, please contact customer service.
http://www.youtube.com/watch?v=goyXOXpXpMc
Thanks for looking!
Phil
Thanks for looking!
Phil
600 whp on stock internals @ 30 psi with C16 is pretty decent. 500 whp on pump gas? I know it said over 500 whp w/ pump gas in the video. Your dyno sheet only shows 402...what gives?
We are testing different cams and things and have hit very high horse power but we want it to be complete, 1 before we sell it. 2 so we completed the car and have consistant dyno graphs to show power tq ext. Will let you know as development continues.
Evan Smith
TurboXS Exhaust for the Evo X
New Stuff from TurboXS is here to give your Evo X a sizable performance boost!
TurboXS is one of the originators in Subaru performance, and brought that knowledge of forced induction over to the Evo! TurboXS is constantly doing R&D to offer the most affordable and performance oriented products available.
Catback Exhaust
- 10whp gain
- Full 3 inch exhaust
- Blue, heat treated tips
Front Pipe
- 15whp gain
- 3 inch stainless steel
- Included 2nd bung for wideband
High Flow Cat
- High flow metal matrix converter
- 50 state legal
Race Pipe
- 10whp gain
Turbo-Back Exhaust and Catless Turbo-Back Exhaust also availabe!
PM, email, phone, AIM... get ahold of me for the best pricing!
Hey Guys,
We got our 5 FP RED turbos for the EVO X in stock, no wait time, ready to roll out.
Forced Performance RED Turbocharger Mitsubishi EVO X 08+
Model: NTEVOXRed List: $1,398.99 PM for special- we ship word wide!!
These are NON ported but they are all Anti Surge!!
As the leader in Mitsubishi Evolution bolt on performance, Forced Performance is proud to released the FP RED for the Mitsubishi Evolution X. This turbo has already rocketed the Big Valley Performance Evo X to an astonishing 10.79 @ 124 mph all while keeping it stock appearing.
This turbo can sustain well over 35psi of boost pressure and still keep turbine back pressure in check due to our proprietary advanced turbine aero and massive turbine blades. Due to the advanced design of the blades the spool up is retained near that of the stock turbocharger. These are the same size internals as used in the popular FP RED for the Mitsubishi Evolution 9 which has already propelled cars to mid 9 second quarter mile passes.
Again these are IN STOCK!!! please call me at 480-966-3040 ext:231 | phil@vividracing.com or PM me for special or any questions. We have a world class tuner on site to help you with tuning if you need it as well
Regards
Phil
Regards
Phil
and are these the antisurge ones?
