Forced Performance EVOX Black turbo at Mellon Tuning
The FP BLACK™ for the Mitsubishi Lancer Evolution X is here. This is the most fully evolved stock appearing variant we offer. It features an 82mm HTA™ compressor wheel with a flow rate of 68lb/min. The turbine side features a large 67mm turbine wheel.
The turbo comes standard with an 18psi wastegate actuator and the FP Evo X High Flow Oil Supply Line. You may select a lower pressure actuator if needed, but the unit is intended to operate above 18psi of boost pressure. This turbocharger will produce 500-600whp results readily on well prepared engines.
$1999.00 and Porting is available for 95.00 extra. Let me know if you need a price shipped to your door, but it's usually about 35.00 in the U.S.
You can place your order here: http://www.mellontuning.com/index.ph...roducts_id=615
Mellon Racing
56
Jul 11, 2011 07:11 AM
Mellon Racing
EvoX 'For Sale' External Engine / Power
72
Jun 27, 2011 07:02 AM
Mellon Racing
EvoX 'For Sale' Interior Styling
14
Jun 19, 2011 08:00 AM
Mellon Racing
Feb 23, 2011 07:38 AM
