Tomei Powered Evo X Intake/Exhaust Instock! :)
What sup forum peeps!
What I have currently instock is for the Evo X, both Intake and Exhaust.
TITANIUM AIR INTAKE PIPE:
Works with 4B11/CZ4A!
INFO:
EVO X ESSENTIAL TUNING UP ITEM LIGHT WEIGHT, STRONGER, FULL TITANIUM INTAKE PIPE:
The stock rubber hose is not suitable for high temperatures and boost pressures that the engine is capable of when pushed for performance. The piping will deform and hinder the air flow to the engines intake. With this TOMEI Titanium intake pipe, the deformation problem is eliminated whilst preventing the loss of boost pressure. With the added benefits of a 25% weight reduction over the stock item with the increased performance gains, makes it an easier point to choose this easy simple upgrade.
DYNO:
TOMEI vs OEM:
TOMEI:
MATERIAL: TITANIUM
PIPE DIAMETER: Φ50.8 - 60.5mm
PIPE THICKNESS: 1mm
WEIGHT: 0.7kg / 1.54lbs
OEM EVO X:
MATERIAL: RUBBER+ALUMINUM
PIPE THICKNESS: -
WEIGHT: 0.95kg / 2.09lbs
MSRP: 290 USD (For Intake)
EXTREME Ti CATBACK TITANIUM EXHAUST:
Works with EVO X
INFO:
- RACING LAYOUT The racing layout has been designed with minimal bends for best exhaust gas flow for best performance gains.
- 3 SECTION PIPE ASSEMBLY
The conventional style flange was not used this time to help reduce weight even further. The use of the springs and clamps eliminates the need for gaskets as well.
- HIGH QUALITY Only a racing style Titanium muffler can deliver the unique true race car exhaust sound that you are used to hearing on a high end pro race car.
- BEST VALUE FOR MONEY PERFORMANCE The design targets were strictly for performance use and for the best value for money for our end users.
DYNO:
TOMEI vs OEM:
TOMEI:
MATERIAL: TITANIUM
MAIN PIPE DIAMETER: Φ80
MAIN PIPE THICKNESS: 1mm
SILENCER DIAMETER: Φ152
SILENCER THICKNESS: 1mm
TIP DIAMETER: Φ115
TIP THICKNESS: 1mm
FLANGE THICKNESS: 6mm
LAYOUT: Single Tip
WEIGHT: 4.4kg / 9.7lbs
OEM:
MATERIAL: STEEL
MAIN PIPE DIAMETER: -
MAIN PIPE THICKNESS: 1.5mm
SILENCER DIAMETER: -
SILENCER THICKNESS: -
TIP DIAMETER: -
TIP THICKNESS: -
FLANGE THICKNESS:11mm
LAYOUT: Twin Pipe Tip
WEIGHT: 20.05kg / 44.2lbs
MSRP: 1290 USD (For Cat-back)
Any other questions or pricing please shoot me a PM, or call in 626 618 1100 x 110
Thanks for looking,
Tuan @ A Spec.
INFO:
DYNO:
TOMEI vs OEM:
TOMEI:
MATERIAL: TITANIUM
PIPE THICKNESS: 1mm
OEM EVO X:
PIPE THICKNESS: -
Works with EVO X
INFO:
DYNO:
TOMEI vs OEM:
TOMEI:
MATERIAL: TITANIUM
TIP DIAMETER: Φ115
TIP THICKNESS: 1mm
LAYOUT: Single Tip
OEM:
MATERIAL: STEEL
TIP DIAMETER: -
TIP THICKNESS: -
Thanks for looking,
Tuan @ A Spec.
RallySport Direct
Oct 17, 2016 03:35 PM
DrivelineSales
Feb 23, 2010 10:24 AM
ChopsatMVP
Nov 7, 2008 08:37 AM
RavSpec
Evo 'For Sale' Engine Internals and Drivetrain
22
Jun 16, 2007 05:12 AM
