Torque solution products!!! All in stock!!!!!
Old Apr 25, 2012 | 08:03 PM
Shaun@AWDMotorsports's Avatar
Torque solution has just released a mustache bar eliminator. After AMS discontinued the product there was a still quite a bit of interest for it so it was remade.. Its offered 3 ways for some of you gusy who have solid diff supports already and for those who want a less aggressive option with urethane inserts..
PM FOR PRICING!!!!
The Torque Solution Mustache Bar Eliminator is designed to eliminate that annoying rear differential "clunk" under hard shifts from the rear of your car. Made from 100% billet 6061 aluminum and CNC machined for accurate tolerances.
*This piece requires SOLID OR URETHANE BUSHINGS!!! We are offering it without the bushings for those of you who may already have the bushings on your car and dont need them but keep in mind they are REQUIRED!!!
-Eliminates the " CLUNK " when shifting hard
-Drops 13lbs off the car
-Reduces wheel hop / traction loss
-Improved 60fts / e.t's
-1000HP+ and 8sec e.t. torture tested
-Lifetime Warranty
-Made in USA
The Torque Solution Mustache Bar Eliminator is designed to eliminate that annoying rear differential "clunk" under hard shifts from the rear of your car. Made from 100% billet 6061 aluminum and CNC machined for accurate tolerances. This piece comes anodized black and includes two solid bushings for the side of the rear differential to allow even less differential movement and clunking.
-Lifetime Warranty
-Made in USA
The Torque Solution Mustache Bar Eliminator is designed to eliminate that annoying rear differential "clunk" under hard shifts from the rear of your car. Made from 100% billet 6061 aluminum and CNC machined for accurate tolerances. This piece comes anodized black and includes two Urethane bushings for the side of the rear differential to allow even less differential movement and clunking. The urethane bushings are less harsh and transmit less feedback into the cabin then the solid bushings.
-75a Polyurethane Bushings
-Lifetime Warranty
-Made in USA
Below is most of the lineup from Torque Solution.. Everything is in stock ready to ship!!! PM FOR PRICING or email Shaun@awdmotorsports.com
NEW
Torque Solution Billet Shift Knob RED or BLACK
Torque Solution billet shift knobs are machined from 6061 Billet material and hard anodized to resist scratching and wear. Each knob weighs 188g / 6.6oz to give you that more positive & smooth feel when shifting. Suitable for all forms of racing and guaranteed to last a lifetime.
Features
- Installs in Minutes
- Weighs 188g / 6.6oz
- Street and track torture tested
- Hard Anodized
- Lifetime Warranty
- Made in USA
Torque Solution Stock Location Tial Blow off Valve Adapter: Mitsubishi Evolution X 2008+
Torque Solution Billet Stock to Tial Blow off Valve Adapter allows you to direct fit your blow off valve to your Stock flanged piping without any welding.. This is a direct bolt on adapter to allow you to fit a Tial 50mm BOV to your intercooler piping.
Torque Solution Delrin 50mm Round Shift Knob: Universal 10x1.25
Torque Solution 2" round shift knob is made from an aerospace polymer Delrin material. Delrin material is impervious to heat and cold. Making it an excellent choice for racing applications and for daily driving in hot and cold climates. It is also not slippery and will not rattle like some metal knobs do. The hole extends as deep as possible to give you the lowest possible installed height..
Features
- Weighs 85g
- Delrin polymer
- Lifetime Warranty
- Made in USA
Torque Solution Delrin Tear Drop Shift Knob: Universal 10x1.25
Torque Solution Tear Drop shift knob is made from an aerospace polymer Delrin material. Delrin material is impervious to heat and cold. Making it an excellent choice for racing applications and for daily driving in hot and cold climates. It is also not slippery and will not rattle like some metal knobs do. The hole extends as deep as possible to give you the lowest possible installed height..
Features
- Weighs 112g
- Delrin polymer
- Lifetime Warranty
- Made in USA
Torque Solution Silicone Inlet Pipe for 3" FP Turbo: Mitsubishi Evolution X 2008-2013
Torque Solution continues to push the limits of high performance aftermarket products with our 4ply Silicone Turbo Inlet Hose. This hose is designed to work with Forced Performance 3" turbos. Our silicone hose smooths the air entering the turbo which allows you to make more power. The inlet is 3" which opens up to 3.5" inches to maximize intake volume and velocity with this tapered design. Made from Lifetime Warranty 4ply silicone chosen specifically by Torque Solution engineers for this application so you can be sure it will perform!!
• Smoothes airflow entering turbo
• Installs in under 15 Minutes
• Eliminates failure prone corrugated rubber hose
• Street and track torture tested
• 4ply Silicone
• Lifetime Warranty
• Made in USA
Torque Solution Billet Aluminum 1.25" Bypass Plug: Universal & EVO/WRX/STi
Torque Solution Billet aluminum bypass plug allows you to plug the hose or intake tube which recirculates when going from non atmospheric recirculating BOV to an atmospheric blow off or diverter valve.
Torque Solution short throw shifter is a direct replacement for your long throw stock unit.Our shifters are made from 4130 Chromoly steel and are Cnc machined to precision tolerances .After this they are set out to be chrome plated to last a lifetime.This is the best mod for your ride.
Features:
- 32% throw reduction
- 1.25" height reduction
- 4130 Cr-Mo steel
- Installs in under 30 minutes
- Compatiable with stock and aftermarket shift knobs
- Changes the factory offset to center shifter closer to the driver
- Life Time Warranty
- Made in USA
The solid differential mount will eliminate movement of the rear end in the subframe. By replacing the rubber mount with this solid 6061 billet unit you are able to get rid of the unwanted slop and flexing of the stock units which allows for the power to go into rotating the tires, instead of flexing the rubber. Giving you better feedback, sharper response, more predictability on throttle input, along with eliminating annoying clunking during hard shifts.
-Reduces the " CLUNK " when shifting hard
-Road Race torture tested
-6061 anodized billet
-25% Lighter than Stock
-LifeTime Warranty
-Made in USA
These Solid bushings are much harder compared to the OEM units. By replacing them with these harder units you are able to get rid of the unwanted slop and flexing of the stock units which allows for the power to go into rotating the tires, instead of flexing the rubber. Giving you better feedback, sharper response, more predictability on throttle input, along with eliminating annoying clunking during hard shifts.
-6061 Anodized Billet
-LifeTime Warranty
-Made in USA
These Solid Polyurethane bushings are much harder compared to the OEM units. By replacing them with these harder Polyurethane units you are able to get rid of the unwanted slop and flexing of the stock units which allows for the power to go into rotating the tires, instead of flexing the rubber. Giving you better feedback, sharper response, more predictability on throttle input, along with eliminating annoying clunking during hard shifts.
-95A durometer bushings
-LifeTime Warranty
-Made in USA
Torque Solution Mounts Increase horsepower by reducing frictional lost due to poor axle geometry. Axle geometry under acceleration is very critical when trying to apply horsepower. Poor axle geometry is caused when engine and suspension center lines are changed. By installing Torque Solution Billet engine mounts engine center line are kept within precision tolerances.For street and race applications. Some vibration noticeable..
•Eliminates wheel hop / traction loss
•Improved 60fts / e.t's
•Made out of lightweight 6061-T6 billet aluminum
•600HP+ and 9sec e.t. torture tested
•Black anodized / Torque Solution Laser engraved
•75A durometer bushings
•Life Time Warranty
•Made in USA
Torque Solution includes 2 urethane bushings and a sleeve for the PASSENGER side and 2 urethane bushings and a sleeve for the DRIVER side. Upgrading your stock rubber bushings to urethane bushings will help reduce engine movement and wheel hop. This means you receive better traction, which will improve your 60ft and 1/4 mile time. Affordable price, easy install, and most importantly you'll see and feel the advantages.
Improved 60fts / e.t's Street and track torture tested
Life Time Warranty
Made in USA
Torque Solution exhaust mounts will reduce exhaust movement and vibrations both under extreme racing conditions and daily street driving. Great compliment to any exhaust kits.
Direct Replacement
•Eliminates Exhaust Movment
•Made From high grade polyurethane
•Street and track torture tested
•75A durometer
•Life Time Warranty
•Made in USA
Torque Solution Drive Shaft Center Support Bushings will replace the OEM Rubber mounts with Delrin Polymer pieces. Doing so will allow for reduced wheel hop, improved acceleration and better E.T's. The mounts keep the propeller shaft from moving under hard acceleration, stopping and turning giving you optimal performance 100% of the time.
-Eliminates wheel hop / traction loss
-Made out of lightweight Delrin
-Less NVH than 6061 Billet
-Street and track torture tested
-Black anodized
-Life Time Warranty
-Made in USA
Torque Solution continues to push the limits of high performance aftermarket products with our "NEW" Shock Factor Shifter Bushings. Developed to perform under the most extreme conditions, Shock Factor Shifter Bushings bridge the gap between ordinary aluminum, brass, and cheap plastics used in current aftermarket shifter bushings by offering a unique Delrin specifically chosen by Torque Solution engineers to ensure product performance and reliability while drastically reducing shifter end play allowing for crisper, more precise shifts. All this makes it easy for us to stand behind our shifter bushings with a lifetime warranty.
Street or Track Shock Factor Shifter Bushings will always get you in gear!!!
• Improved 60fts / e.t's
• Eliminates excessive Shifter play
• Installs in under 30 minutes
• Life Time Warranty
• Made in USA
Torque Solution shifter base bushing kit replaces the OEM rubber bushings on the bottom of the shifter providing a more stable shifter platform and mounting points. This yeilds improved shifting feel and characteristics for years of enjoyment.
• Cnc machined 6061-T6 billet aluminum
• Made in USA
Replace your long factory antenna with our billet shorty antenna, Giving you a new style to your car.
- 2" inch Tall
- Installs in under 2 minutes
- Made out of lightweight 6061-T6 billet aluminum
- Black anodized
- Lifetime Warranty
- Made in USA
Torque Solution Gate Selector Pivot Bushing eliminates much of the shifter play felt on the Evo X models. Giving you a more precise feel in between gear changes. Get rid of that sloppy and less than direct feeling the Evo X has with this Delrin 2pc replacement kit.
-Reduced Shifter Play
-Self Lubricating
-Life Time Warranty
-Made in USA
Old Apr 27, 2012 | 08:19 AM
bump
Old Apr 30, 2012 | 01:44 PM
ttt
Old May 11, 2012 | 09:47 AM
bump
Old May 15, 2012 | 11:24 AM
ttt
Old May 18, 2012 | 09:20 AM
bump
Old May 23, 2012 | 10:23 AM
ttt
Old May 25, 2012 | 09:12 AM
bump
Old May 25, 2012 | 10:24 PM
B^t's Avatar
B^t
Free bumps! Thanks for the torque solution ss too.... Smooth transaction and delivery....
Old May 29, 2012 | 09:34 AM
Thanks...
Old May 31, 2012 | 08:43 AM
bump
Old Jun 8, 2012 | 12:20 PM
ttt
Old Jun 12, 2012 | 09:19 AM
bump
Old Jun 19, 2012 | 12:52 PM
ttt
Old Jun 22, 2012 | 12:16 PM
ttt
