Unbeatable Exhaust Pricing, Service and Selection! ETS/MEGAN/GREDDY/TOMEI/COBB & MORE
Old Dec 5, 2012 | 03:00 PM
  #46
maperformance's Avatar
The NEW MAPerformance site is up and running! Be sure to check it out!
Old Dec 6, 2012 | 03:06 PM
  #47
Have you stopped by our clearance section on our website?
That's right, We are CONSTANTLY updating our site with clearance items that either we are over stocked on, simply have been sitting on for too long, OR simply want to pass on savings to our customers!
Select the car below to be taken directly to the clearance section for your vehicle:
EVO 8/9
EVO X
Old Dec 7, 2012 | 02:04 PM
  #48
MAP is proud to bring you this amazing CNC machined aluminum spark plug cover that is anodized black with the “MAPerformance” logo machined onto the face. This cover is perfect to dress up any street/strip car for a nice clean look, or top off your show car with that finishing touch.
Features:
  • Tough Anodized Finish
  • All Hardware Required For Installation
  • Drop On Fitment
  • “MAPerformance” Engraved
Part # – EVO-SPC
Our Price – $129.99
Click Here To Order!
Old Dec 10, 2012 | 02:14 PM
  #49
MAP offers stock replacement, short runner, tubular manifolds for both the EVO 8/9 AND the EVO X!
Our new tubular stock replacement exhaust manifold is made of high quality mandrel bent SUS304 stainless steel and electronically tig welded at all joints. Our manifold is designed to retain your factory turbo orientation. The shorter length runners help to increase spool while still allowing for big power gains up top!
EVO 8/9:
EVO X:
Old Dec 11, 2012 | 01:48 PM
  #50
Map is proud to announce the new EF 2.5 turbo for EVO X!
Introducing the MAP EF2.5 turbocharger, the latest addition to the EF family of turbochargers. The EF2.5 is the product of overwhelming demand for something between our EF2 and EF3 variations, owners can expect a significant increase in power output with only a slight loss in regards to spool characteristics compared to the EF2.
This turbo has all the engineering MAP could throw at it including upgraded thrust components with dual oiling ports for improved lubrication, and a brand new blade profile that is super efficient and will outperform any wheel with the same inducer/exducer dimensions. What more could you possibly be after? Well if it's more power, check out our EF3 setup!
Details
The EF2.5 is capable of up to 500whp (as measured on a DynoJet)
Billet compressor wheel with MAP exclusive blade design
12cm twin scroll turbine housing
Standard compressor housing
Includes 18psi Turbosmart actuator and additional 5psi spring (yields 23psi base pressure when installed)
Includes MAP 3" turbo inlet (retains stock oil feed line, upgrade optional)
Options
Compressor Housing Porting
Turbine Housing Porting
Thermal Coating
and as always MAP offers it's satisfaction guarantee:
Customer satisfaction is our highest priority!
If for some reason you are not happy with your MAP turbocharger simply send it back to us within 30 days from the date of purchase and we will refund you 100% of your purchase price for that item.
Please note the turbocharger must not be damaged or altered in any way, and all accessories must be included within the return shipment.
Old Dec 12, 2012 | 02:23 PM
  #51
MAP - Refurbished EF Series EVO 8/9 Turbos? Only ONE turbo left to sell...contact me via PM if you want one!
This turbo has been fully refurbished and include the same warranty as if it was sold new. We are able to offer this to the public at drastically reduced pricing so if you're interested please act fast!
EF3 - SOLD!
*Includes a Forge Billet WG Actuator (19-24PSI)
*No porting or coating
*This comp cover does not have "MAP" embossed
Quantity 1 x EF4 - $1599.99 ONLY ONE LEFT!
*This comp cover does not have MAP embossed
*Includes larger diameter outlet pipe
Old Dec 13, 2012 | 10:23 AM
  #52
Old Dec 14, 2012 | 12:28 PM
  #53
Did you know that MAP has a package deal section on our website for many of the vehicles we specialize in?
That's right, NOW you can get package discounts on brake kits, clutches, headgasket/ head service parts, engine internals, fuel supply components 24/7 simply by surfing the site!
Select the car below to be taken directly to the package deal section for your vehicle:
EVO 8/9
EVO X
Where you will find package deals like:
AND MORE!
Old Dec 17, 2012 | 03:48 PM
  #54
MAPerformance is proud to offer everything Stance for all your coilover needs!
Super Sport
Super Sport is our main flagship line of coilovers. Featuring an industry leading oversized casing with inverted monotube technology standard, Super Sport dampers have a higher oil capacity and larger piston diameter resulting in access to a wide range of adjustment for ultimate response without compromise. Drivers of all levels can easily adjust the damping for a sport-tuned yet comfortable ride on the street and are able to quickly dial in a more aggressive setting for characteristics needed at the track.
Utilizing the very same technology found in top tier racing, Stance Suspension development of the Super Sport coilover answers the demand for a true high performance suspension able to conquer the challenging dynamics of the street. The days of sacrificing ride quality for performance are over!
Super Sport+
Super Sport+ coilover has all the features of the Super Sport+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.
Pro Comp
Pro Comp is our top of the line single way adjustable coilover. Pro Compfeatures industry leading large 60mm OD casing, which reduces rod pressure for consistent performance.The newly desgined "sensing" piston responsds with full damping capability within as little as 2mm of shaft movement. Instant reaction to changing road surface equals traction and comfort.
Pro Comp features inverted monotube (strut type) construction for consistent valving and to withstand high lateral forces of racing. Swift springs are made from H5S.TW which is stronger than regular silicone chrome material. Stronger materials allows for less coils, which makes them lighter, more consistent, and offer more stroke than any other springs brands.
Pro Comp features double reinforced lower bracket (strut type) to ensure minimal deflections during high lateral cornering. XR is a no compromise high performance coilover for those who seek the ease of single adjustable valving.
Pro Comp 2
Pro Comp2 is our top of the line coilover. The Pro Comp2 features 2-way adjustability, enabling the driver to fine tune compression separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
Pro Comp 3
Pro Comp 3 is our top of the line coilover. The Pro Comp 3 features 3-way adjustability, enabling the driver to fine tune low-speed and high-speed bump separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
We carry many different lines of coilovers and suspension upgrades so don't hesitate to ask for you are looking for anything else!
Old Dec 18, 2012 | 02:45 PM
  #55
MAPerformance - YOUR resource for the best pricing around on Competition Clutch AND ALL clutch solutions.
Competition Clutch specializes in manufacturing sport compact assemblies from street driven to full race applications. You will find our products being proudly used in some of the fastest sport compact race cars in the country, including a number of the most recognized industry icon vehicles.
Competition Clutch, featuring their all new Stage 3 Segmented Ceramic Clutch Kit
This segmented Ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life.
Old Dec 19, 2012 | 01:23 PM
  #56
Did you know that ALL MAP Fab in house manifolds are built with the following features?:
100 Percent polished schedule 10:
MAP invested hundreds of hours into developing a system to polish schedule 10 to our specification including research into the best possible tumbler, sampling a wide array of aggregate to generate the perfect finish to start with.
All manifolds welded on back purge stations
ALL MAP in house fabricated manifolds are tig welded and 100 percent back purged. This a process by which shielding gas is introduced to the interior of the welded area to prevent the molten metal from being exposed to oxygen. This results in stronger, more uniform and cleaner welds.
All MAP in house fabricated manifolds come with thick, laser cut/cnc'ed stainless flanges
Resulting in longer lasting and more aesthetically pleasing parts
All MAP in house fabricated manifolds come ported
Where some companies will simply grind away excess material for a simple transition into the runners, MAP manifolds are actually ported and shaped for maximum flow.
All MAP manifolds are backed by our Lifetime Ownership Guarantee!
When purchasing a MAP manifold, purchase with confidence. We guarantee that manifold for the lifetime of your ownership of it (valid for the original purchaser only).
MAP Complete T3 Turbo Kit (Mitsubishi Evo X)
The wait is finally over as you can now get the MAP treatment in a T3 configuration using some of the best components available! Choose from four killer PTE turbochargers (please don't hesitate to contact us for suggestions) and turn your horsepower dreams into a reality. This kit includes every component you will need to complete the installation.
Included Components
Turbocharger of your choice
3" Stainless Steel V-Band Downpipe with Flex
304SS Tubular Exhaust Manifold with CNC Transition Head Flange to 1.5" Primaries
Cam Angle Sensor Heat Shields (not pictured)
Turbosmart Comp Gate 40 Wastegate
Wastegate Dump Tube
Stainless Steel Upper Intercooler Pipe
Oil Feed and Return Lines
All Applicable Gaskets, Hardware, Clamps and Couplers
Old Dec 20, 2012 | 12:52 PM
  #57
EF3 - SOLD!
Old Dec 21, 2012 | 03:13 PM
  #58
Old Dec 26, 2012 | 02:31 PM
  #59
JUST Released! MAP is proud to announce our MAP Rear Upper Intercooler Pipe for the 2008+ Mitsubishi EVO X
Just Relased! The MAP Mitsubishi Evo X Rear Upper Pipe works by replacing the factory pipe that necks down to 1.75″ at the turbo outlet with a full 2.5″ pipe to increase power and reliability. It is fully Tig welded by master fabricators and uses high quality 304 stainless steel to not only dress up your engine bay, but get that extra kick in horsepower!
Features
Mandrel Bends
Fully Tig Welded
Made from 304 Stainless Steel
4-Ply Silicone Clamps
T-Bolt Clamps
All Mounting Hardware Included
Part # – EVOX-UICP
MSRP – $119.99
Old Dec 27, 2012 | 03:14 PM
  #60
Super Sport
Super Sport+
Pro Comp
Pro Comp 2
Pro Comp 3
Quick Reply: Unbeatable Exhaust Pricing, Service and Selection! ETS/MEGAN/GREDDY/TOMEI/COBB & MORE
