MAPerformance Fabrication & Porting Services
Old May 15, 2013 | 03:26 PM
  #151
maperformance's Avatar
MAPerformance - Proud to be your number one source for all things Tomei!
Mr. Seiichi Suzuki initially forged TOMEI is a tuning factory for race cars back in 1968. (Established as TOMEI JIDOUSHA Co. Ltd). From that day onwards TOMEI achieved excellent results in various motor sports categories. TOMEI was then recognized for its technology, performance and reliability that we had cultivated into our own design products and had a large support base from motor sports end users and tuners. Then the "TOMEI" brand was born through experience.
With the new market trends & demands, motoring enthusiasts wanted better performance to suit the new modern lifestyle. This trend helped set the stage where originality can play an active part in the motor sports scene and personal motoring lifestyle.
From Exhausts, to engine internals, to turbos, Tomei offers products to fill just about every category:
Tomei's has created a new line of titanium exhausts for latest import cars. Tomei titanium exhausts are designed for the best power and response, but keeping the great characteristics of the original engine. Each exhaust is tuned for each car and the least restrictive angles are chose to optimize power and torque. The thin titanium exhaust gives a true race style exhaust, but can also toned down with the included silencer.
The PROCAM series are for the serious users who need results when every milla-seconds count.
TOMEI Valve Springs
In terms of transferring the exact movement of the camshaft, the highest quality valve spring is required to the high RPM, high powered tuned engines. We developed our products with the most careful choice of the material, coating and the other technologies. Then we repeated severe tests to our pre-production in order to give the best quality that is performed in any situations.
Features
Reliability in high RPM, and improvement in an initial response
High durability against metal fatigue
High durability against the shocks from jump and bounce
High durability against surging
High sag resistance
Tomei Adjustable Cam Gears are designed specifically for each and every application. The pulley and gear are made from Duraluminum material for less weight and increased strength. Tomei adjustable cam pullies are sliding types with timing degree markings that allow the fine tuning of the valvetrain for optimized power.
Anything and everything Tomei offers, WE offer! Please feel free to shoot me a PM with any inquiries!
Nate
Old May 16, 2013 | 07:26 AM
  #152
Did you know that MAP has a package deal section on our website for many of the vehicles we specialize in?
That's right, NOW you can get package discounts on brake kits, clutches, headgasket/ head service parts, engine internals, fuel supply components 24/7 simply by surfing the site!
Select the car below to be taken directly to the package deal section for your vehicle:
EVO 8/9
EVO X
Where you will find package deals like:
AND MORE!
Old May 17, 2013 | 07:08 AM
  #153
MAPerformance is proud to announce the release of the MAP T4 Twin Scroll Top Mount Turbo Kit for the Mitsubishi Evo X
For real "Seat of your pants" power upgrades, Look no further then MAPs T4 Twin Scroll Top Mount Turbo Kit! Made in house from the highest quality stainless steel, fully tig welded and ported for maximum flow.
This kit is features an equal length MAP manifold, full 3" Downpipe, 2 routed Wastegate dump pipes, stainless high flow upper intercooler pipe, Dual Turbosmart CompGate40s and any T3/T4 or Garret GT Series Turbo. This turbo kit will be at home on the track or the street.
*Compatable With SST Transmission*
Includes:
Turbocharger
MAP Stainless Downpipe
MAP Stainless Exhaust Manifold
MAP Wastegate Dump Tubes
MAP Upper Intercooler Pipe
MAP 4" Intake (3.5" MAF housing)
Clamps and Couplers
Oil Feed and Drain Lines
Turbo Gaskets and Hardware
Everything Is Included For a Complete Install
Old May 20, 2013 | 07:33 AM
  #154
MAP is proud to offer you D2 Coilovers for all applications including EVO 8/9 and X!
RS Series:
The RS Series suspension kit is our most popular coilover. Featuring a 36-way damping and rebound adjustable monotube design, RS Series coilovers are perfect for the modified street car that also sees occasional track days. This coilover has separate height and preload adjustments allowing for optimal suspension tuning while maintaining full strut travel at all times.
Features:
36-way damping adjustable monotube shock assemblies
Full ride height adjustability with separate spring preload
Anodized finish and Teflon coated threads to prevent rust
Upper camber plates and pillow ball mounts* (6061 Aluminum construction)
1 Year Manufacturer’s Warranty
Serviceable in the USA
Circuit Series
D2 CIRCUIT Series coilovers are designed for the circuit track enthusiast determined to go fast. Increased spring rates with more aggressively valved dampers and a larger, heavy-duty piston construction result in a suspension system that out-performs its competition. Large 52mm shock bodies increase oil capacity and the aluminum construction decreases weight to help this coilover perform at the limit.
R-Spec Series
D2 R-SPEC coilovers are the ultimate suspension system for the serious race competitor. Premium construction, race-spec spring rates with matched valving, and remote reservoirs make this our top-of-the-line coilover. This system allows you to fine tune your shock’s compression and rebound independently while helping to maintain acceptable shock oil temperatures under the most demanding race
PM us for exclusive pricing on these and MORE options for your ride!
Old May 21, 2013 | 06:48 AM
  #155
MAP - Proud to introduce the new EVO X Stainless Steel Upper Rear Intercooler pipe!
The MAP Mitsubishi Evo X Rear Upper Pipe works by replacing the factory pipe that necks down to 1.75" at the turbo outlet with a full 2.5" pipe to increase power and reliability. It is fully Tig welded by master fabricators and uses high quality 304 stainless steel to not only dress up your engine bay, but get that extra kick in horsepower!
Features
Mandrel Bends
Fully Tig Welded
Made from 304 Stainless Steel
4-Ply Silicone Clamps
T-Bolt Clamps
All Mounting Hardware Included
Old May 22, 2013 | 06:52 AM
  #156
EVO 8/9
EVO X
AND MORE!
Old May 23, 2013 | 07:39 AM
  #157
Precision Turbo - NOW Stocking all popular Turbo's!
In an attempt to cut down delivery times for all popular turbos, PTE is now stocking on the shelf, ALL popular options so that WE can get them shipped out to you ASAP!
PM me for pricing anything and everything Precision Turbo!
Featuring the latest and greatest in compressor and turbine wheel technology from Precision, the PT6266 CEA offers a unique combination of Competition Engineered Aerodynamics (CEA) with both hot and cold sides! Offering a 30-45 horsepower increase over similarly sized turbine wheel equipped turbos, the PT6266 CEA is the perfect choice for those wanting to make more power without changing their current system.
Precision customers have a history of setting records and getting noticed. They don't sit in the stands watching the action – they're the ones making it happen. Innovation is a collaborative process and we focus our efforts on you. Get involved and be a part of the action today with .
SOME of the features PTE Turbos include are:
• Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
• Higher efficiency and faster transient response for maximum power and performance
• Available with either a Hydrodynamic 360° thrust bearing system, or an Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
Old May 24, 2013 | 05:06 PM
  #158
RS Series:
Features:
Circuit Series
R-Spec Series
Old May 27, 2013 | 07:05 AM
  #159
Features
Mandrel Bends
Fully Tig Welded
T-Bolt Clamps
Old May 28, 2013 | 07:01 AM
  #160
Exedy Cerametallic Stage 4/5 Triple SR Clutch Kit (Mitsubishi Evo 8/9) MM023SR
IN STOCK HERE and ready to ship!
That's right, I literally have too many of these kits in stock. PM ME, NATE for the best pricing available! I won't be beat in pricing!
And while we are on the topic, I ALSO just got a HUGE shipment of twins in here...truth be told, I am worried I might have bought too many of those too...so if you are in need of an Exedy twin, shoot me a PM! I am motivated to reduce that inbound shipment a bit!
Exedy Cerametallic Stage 4/5 Twin HD Clutch Kit (Mitsubishi Evo 8/9) MM022HD
So once again...just to clarify...I got an amazing deal on SR Triples and HD twins and I think I might have purchased too many! PM ME if you want one...I have about a dozen of each I would like to get out the door and I am GOING to blow them out the door!
Old May 30, 2013 | 07:32 AM
  #161
RS Series:
Features:
Circuit Series
R-Spec Series
Old May 31, 2013 | 06:20 PM
  #162
The MAP Tubular Manifold for the Evolution X platform is now available!
Click here for initial testing that resulted in an amazing 40whp+ gain with a BBX turbocharger!
Polished
Advanced Ceramic Coating (All Ceramic Coating orders can take up to 2 weeks before shipment)
- Direct replacement for stock frame Evo X turbochargers
- 1.25" primaries for maximum velocity and spool characteristics
- Schedule 10 304SS tubing for the utmost in durability
- 304SS flanges featuring a CNC transition from cylinder head to primaries
- Available in semi-polish (pictured) or with our advanced ceramic coating
- Finish porting of CNC transition to primaries and merge collector
- Fully backpurged TIG welded construction
- Fits with OEM firewall heatshield
- Lifetime warranty against defects to the original purchaser
MAP Stainless Steel O2 Eliminator Downpipe for Evo X
This integrated O2 housing downpipe, or O2 eliminator as they are often referred to, does just
that by removing some of the largest restrictions in the factory exhaust system for significant
horsepower gains throughout the power band! Features / Benefits
* Full 3" design reduces exhaust restrictions.
* Made from 304 stainless steel for superior corrosion resistance and enhanced appearance.
* Mandrel bent tubing throughout optimizes exhaust flow.
* Stainless steel flex section reduces stress from engine movement increasing longevity.
* Optimal wastegate dump location helps eliminate boost creep.
* Includes stainless steel turbo outlet gasket (not shown).
* 100% Made in the USA.
MAP Stainless Steel CompGate40 O2 Eliminator Downpipe for Evo X
Features / Benefits
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: NateAtMAP|||||: 1-888-MAPERFORMANCE x 114|||||: Nate@MAPerformance.com|||||Click to chat for an instant quote!
Like us? Tell us and everybody else about it!
Old Jun 3, 2013 | 07:20 AM
  #163
EVO 8/9
EVO X
AND MORE!
Old Jun 4, 2013 | 04:50 PM
  #164
TOMEI Valve Springs
Features
High sag resistance
Nate
Old Jun 5, 2013 | 02:14 PM
  #165
Polished
Features / Benefits
