Fortune Auto, BC racing, Whiteline, Hawk, Agency Power, Perrin and more @ IIR!
PM us OR call 239-540-6385 and mention BILLY to receive special pricing ON EvolutionM!!!!!
New Series 4!!
EvolutionM, We are now the Master Dealers of Fortune Auto coilovers!
**Join their Facebook page!** Fortune Auto's Facebook Page
Custom Spring rates are FREE OF CHARGE!!
All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification. Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers.
Features:
* Dyno tested***
* Stainless steel body / piston
* 30-way adjustable dampers
* Pillowball mounts
* Forged aluminum locking collars
* Dust boots on all pistons
* 50mm piston (beyond the industry standard of 44-47mm)
* Anodized aluminum camber plates** on front upper-mounts
* Fully anodized body
* 1 year Manufacturer's Warranty
* Height adjustment independent of preload
* ISO 9002 certification
Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification.
These Coilovers go LOW!!!
Custom Spring Rates!! Done in the U.S.A!
Custom built to your specifications.
A true solution for your racing requirements!!!
Incorporates all the great features of our 500 & 510 series coilovers.
Furthermore it includes these key features.
Remote reservoirs for increased fluid capacity and cooler operation in race conditions
Separate compression and rebound control
Rebuildable in the USA!
Japanese made forged piston rod
Japanese made nitrogen gas chamber
Every set of Coilovers gets dyno'ed , matched, and tested to the highest standards
Every set includes a printed sweep Dynograph thru the click range providing graphical and numerical proof!
We are also the #1 Vendor in the nation for BC Racing coilovers!
BC Racing BR series Coilovers!! Free Custom Spring Rates as well!!
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
BC Racing RAM type (Inverted)!!!
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series!!
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
ISC Coilovers $955 shipped!!! PM us for best pricing
ISC is a new brand here for the US market, but they have been present in Australia and Asia for some time now. Free shipping. Features: All coilovers come with 12 months warranty to put your mind at ease, if our product fails in any way in the first 12 months we will pay all postage, labor and parts costs to fix the problem in minimal time. If our product fails after that 12 month period we will replace the parts at trade price! We never stop looking after our customers. The N1 coilover can be lowered approx 3 inches lower then standard ride height, this along with a spring rate setup to suit your car improves handling and stability dramatically. we make packages for drift/rally/drag and of course street, to help our customers out even more we give them the option to pick there own custom spring rates at no extra charge.
Features:
32 Step Damper Adjustable
Precise control damp valve
Operates smoothly on all road surfaces
Expansion/Suppression of shock adjustment Pillowball Uppermount
Piston Rod Design - High rigidity steel piston rods
Made from high quality SAE9254 steel
Ride Height Adjustable
Full length height adjustable
Bound adjustable with separate spring locks
Aluminium Bracket
Specifically anodised surface to prevent inside corrosion and surface rust
Single Cylinder Design
Larger cylinder and piston design to advance driving stability and dexterity
Adjustable camber allows more/less on road track for all conditions. N1 Series coilovers meets with race/sport standards Sports Spring. Tested over 500,000 times on compression inspection with less than 5% deformation. They are made with high quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force. On various models camber can also be adjusted via the bracket as well as the camber tops.
We also carry a wide range of Suspension arms/parts!
Whiteline Front/Rear Swaybars for Evo 8,9, & 10
Agency Power Rear Adjustable Control Arms!
Perrin Adjustable Rear Sway bar for Evo 8,9, & 10
Hotchkis Adjustable Rear Swaybar for Evo 8,9, & 10
Whiteline Front Roll Center Adjustment Kit for EVO 8,9, & 10!
Whiteline Front Spherical Endlinks 03-06 Evo 8,9, & 10
Perrin Rear Endlinks for Evo 8,9, & 10!
Perrin Rear Stout Mounts for EVO 8/9
Energy Suspension Master Bushing Kit for EVO 8 & 9
DBA 4000 Series Front Drilled & Slotted Rotors
StopTech Power Slot Slotted Rotors
Technafit and Stoptech Brake lines!
Hawk Full line of pads!
Motul RBF600 DOT 4 Factory Line Brake Fluid!
Motul is 100% synthetic fluid for hydraulic-actuated brake and clutch systems. Motul is specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. Motul RBF 600 offers Extreme thermal resistance and stability. Motul's RBF 600 has an elevated boiling point, 312 C / 593 F with factory brake lines, enabling effective braking even under the extreme conditions of competition. Motul RBF 600 is very efficient in wet conditions; the very high wet boiling point, 216 C / 420 F with factory brake lines, is superior to conventional brake fluids and provides a particularly efficient braking system in rain and retards the apparition of vapor lock. Price is for .5/liter.
Disclaimer- Ad specials not valid on website, only valid by calling or 239-540-6385 visa/mc or paypal/googlecheckout.com shipped pricing refers to the 48 states. If you send a payment and live in FL and do not add 6% sales tax, your item will not ship. All returns subject to 35% restocking fee so make sure you want the part before you buy it! if received after 7 days, store credit will be given. after 2 weeks, returns will not be accepted. price subject to change due to manufacturer changing prices.
Questions: Billy (239)-540-6385
(email)billy@importimageracing.com
AIM- importimagebilly
it is friday! IIR will be at the Performance Racing Industry show this weekend, please leave us a PM, email, or voicemail and we'll get back to you as soon as we can!
Come on in for the best deals @ Import Image Racing! Make your own combo pack for even greater discounts!!!
We're here to help you get the parts you need! Don't see something you need? Chances are we can get it
Feel free to PM/Call/AIM us at any time during the day, we are open almost all the time!!
Regards,
Billy@importimageracing.com
804-690-2452
AIM: ImportImageBilly
Regards,
804-690-2452
Create your own coilovers/arm part combination for the best deals!
Regards,
804-690-2452
Regards,
804-690-2452
Merry xmas EVE EVE BUMP!!!!!!!!!
Regards,
804-690-2452
Regards,
804-690-2452
Merry X-Mas from your friends at Import Image Racing! Enjoy your day with your families and for those who do not celebrate we are here til 330pm then back tonight to answer questions/pms! Although its not thanksgiving...we are thankful for all of you
