ETS 61mm installed pics
It is the 6152RE turbo. It is actually slightly larger than the GT35r. Pretty much identical compressors, 61mm ind. and 82mm exd., and has a 2mm larger turbine, 70mm on PT61 and 68mm on the GT35r. The housing are different though too, I have a .60a/r on the compressor housing instead of the standard .70a/r on the GT35r and a .63a/r exhaust housing, instead of the standard .82a/r housing on the GT35r.
I bet they got an stage V turbine wheel in your turbo....I think they also call it a T350 wheel. I just looked at precisions site....that got all kinds of freakin weird numbers now!
I'm going bigger eventually, won't have any numbers for anything this year, Blew the t-case and trans so it's at shep right now
next year i'll be doing somthing great. Rich got his tuned by Ivey but had a bad leak so he's going back
^what was his #s on the 58 trim??? Where is he leaking from?
Glad to see you are going big next year. I am actually in the process of getting my 2.3 stroker and AEM Meth kit ordered here in a couple of days. I may jump up to a 61mm. Good luck next year....
Great results Nick! I knew it was there for your tuner to take so I'm happy to see that they did it up right
And to think, that turbo doesn't even come alive until 26+psi
You're going to have a monster on your hands!
Tom
You're going to have a monster on your hands!Tom
.....on pump too....
