ExtremeTurboSystems.com – WA Custom Intercoolers, Intercooler Kits, Turbo Kits and Performance Parts. [Visit Site]
Help, whats the best ets turbo kit for me?
Old Nov 11, 2007 | 02:01 AM
1mad evo's Avatar
Im having drop in pistons and rods (weisco and manley i beams) done in two weeks along with s1 cams.
i cant decide which one of your turbo kits will suit me best;
The 61 trim is closest to gt35r right and 58 trim is 3065 type?
as im staying 2 litre and the car will be run on pump gas most likely around 30 psi, i dont want the car to be too undrivable, it is just a weekend fun road car.
power goals id like to see at least 600 at the flywheel and over 500 ft'lb torque.
I have heard that the bigger the turbo the less torque il get, how true is this? torque means a lot to me so i might consider a smaller maybe 57trim if it means more torque.
Look forward to hearing from you
Thanks
Old Nov 11, 2007 | 06:13 AM
DTM2188's Avatar
Tom at ETS will help you get the best trubo kit for you needs, shoot him a PM or call over there and you'll be set.
Old Nov 11, 2007 | 09:07 AM
SickSilverNLow's Avatar
Talk to Tom but I can tell you man......30 psi is going to be hard to accomplish on pump gas . Pump and meth you can do 30 psi.
Old Nov 11, 2007 | 09:15 AM
electricevo's Avatar
30 psi on pump will not happen. Youll be at the knock threshold well before that. if you add alky to the mix, your goal will be more realistic.
Old Nov 12, 2007 | 11:06 AM
ETS Michael's Avatar
These guys know what they're talking about! Adding in meth or alcohol injection to the mix will get you safely to 30psi with pump fuel. At that boost pressure you're right on the line of where I'd recommend a 57 trim or 61mm (35R) for maximum compressor efficiency. With that in mind, to make those numbers while retaining fastest possible spool and transient response, it will take all that a 58 has to give. A 57 trim/58 will spool about 400-500RPM sooner with awesome transient response, but our 61mm kits are hitting full boost by 4800 which isn't at all unreasonable for a street driven EVO. The further "right" on the graph you move the peak torque, typically the lower it is in relation to your horsepower number. I'd welcome the opportunity to discuss your priorities over the phone so we can put first things first! Let me know if I can help
Tom
Old Nov 12, 2007 | 11:57 AM
1mad evo's Avatar
Hi Tom, if you dont mind i will give you a call in the next couple of days once i finalize things on the engine build front.
Thanks
Old Nov 13, 2007 | 08:16 AM
I look forward to discussing it with you then!
Tom
CBRD
25
May 1, 2008 05:12 AM
voidhawk
Nov 10, 2007 06:04 PM
evilevo2006
62
Aug 8, 2007 12:51 PM
rocket900rr
Automotosports - Illinois
91
Jan 25, 2007 05:31 PM
2003lancerevo8
156
Oct 3, 2006 01:17 AM
