Does the Evo IX have Drive by wire?
Old Mar 17, 2005 | 05:04 PM
jude's Avatar
It does not have to cost 5,000 for a turbo kit for a VW. They can be had for half the price.
Old Mar 17, 2005 | 05:19 PM
D1_EVO8's Avatar
maybe you dont see the big loop is because the pic is from a right hand drive EVO9... so the cable routes diffrently and doesnt need to "loop"
Old Mar 18, 2005 | 03:21 PM
ru4real's Avatar
They may have rerouted the throttle cable because MIVEC was added and changed the shape of the valve cover.
Old Mar 19, 2005 | 05:54 AM
smittyinva's Avatar
I think we have a winner.
Old Mar 19, 2005 | 06:37 AM
akEvo's Avatar
drive by wire sucks... hense the reason why i am on this forum and reconize two others from the past
oh and this is my first post
Old Mar 19, 2005 | 09:09 AM
wrcevo's Avatar
Originally Posted by SilverEvo8owner
Drive by wire sucks IMO, or at least for a car like this. I'd prefer to be completely in control. There's a lot of room for error on a drive by wire system, and the sensitivity and response just isn't like traditional setups..
If u like to be completely in control, why not don't have power steering ( which is also drive by wire ) and use some small Momo steering wheel.
Old Mar 19, 2005 | 11:24 AM
bellrose's Avatar
tremors in your foot
Is this normal?
Old Mar 19, 2005 | 11:32 AM
JDM-Spec.com's Avatar
The right hand drive dosn't have the same wire we have on our left hand drive.
Old Mar 19, 2005 | 01:31 PM
BakZamGai's Avatar
Originally Posted by pjohnson0301
DBW sucks ***. That's why I'm selling my 337 VW for an Evo as soon as I can. How much is a decent Evo turbo kit... ~$2,600? At a minimum it would cost me $5,000 to do a turbo upgrade for my car to make a maximum 300 whp. Why...because there's not one standalone or piggyback ECU out there that can control a throttle plate. We got all of 4 chip tuning companies out there that tune the Bosch Motronic and only one of those has a reliable turbo kit/chip tune combination. And none of them have user adjustable anything. Now that sucks.
I believe the Motec M400, M600 and M800 ECUs have provisions for drive by wire applications.
Old Mar 20, 2005 | 02:28 PM
pjohnson0301's Avatar
None that put down ~300hp.
Only the M800 can control "some" Bosch Motronics ECUed cars. It's also hugely expensive and it's totally custom...not plug-n-play.
Old Mar 20, 2005 | 02:33 PM
zlancer's Avatar
Even if it was DBW and you were going to run a standalone you could just swap in a cable throttle setup. Easy. Problem solved.
Old Mar 20, 2005 | 03:08 PM
astondg's Avatar
That's strange because this page http://www.motec.com.au/oem.htm says that MOTEC make an M800 Plug 'n' Play ECU for the Evolution VIII and STI. They also made the same ECU's for previous Evolution's so I don't see why they wouldn't do the same for the IX.
Aston
Old Mar 20, 2005 | 06:32 PM
BakZamGai's Avatar
The M400, M600 and M800 all feature the Drive By Wire option so I don't quite understand why the M800 would be the only one that can control the ECUs you mentioned. As for the ability to control the DBW throttles, wouldn't it be a matter of calibration on the tuners part?
Plug-n-Play is dependent on market demand for such a product. If market demand for the VW cars is high enough, I'm sure aftermarket ECU manufacturers will jump into the market.
Old Mar 21, 2005 | 08:49 AM
Aston
Yeah but we're talking about if the IX comes with DBW which it prolly won't so it's really a moot point.
You must not realize how many cars VW/Audi/Seat put the 1.8T in. The demand is most definately there...but who can afford $2,000+ for engine management that's not PnP, has no "base maps" and no tuner support.
It says on the Motec website:
"MoTeC Drive By Wire is available for certain Bosch, Delphi and Nissan systems using our M800/880 series of Engine Management Systems"
Also, VW pays Bosch lots-o-money to change the Motronic code year to year making base maps impossible. Every time a new ECU code comes out it take the tuners sometimes months to produce a viable chip tune.
Old Mar 21, 2005 | 08:57 AM
alleggerita's Avatar
The evo power steering is not electronic unlike the system used on some BMW's. Correct me if I am wrong.
And yes with a Motec you can get rid of all the undesirable characteristics of an electronic throttle. But that comes at a huge investment. To get this absolutely right with the same or better drivability than stock you are going to lay out a pretty penny and then you probably won't pass emissions - and yes there's always an alternate map for more dollars to help you pass emissions.
