Evo IX- Piston rings....
Old Sep 15, 2005 | 10:39 AM
Sschmuve1's Avatar
I just finished watching the Best Motoring Vid on the Evo 8 vs 9. They say the 9 has 2 piston rings instead of 3. Will this be a weakness from the aftermarket tuning aspect? Can this limit max boost pressure it can withstand before allowing blow-by? I see there is a lot of attention to the Mivec being a problem, but what about this?
Old Sep 15, 2005 | 10:44 AM
shivaswrath's Avatar
i know personally when I built up a motor on my domestic, I opted for a 3 ring system since I was turbocharging it. . .conventional knowledge holds more rings=less blow by=less oil consumption, but they're purporting 2 rings=less oil consumption, so I'm just confused with the Mitsu engineers on this one. . .
Old Sep 15, 2005 | 10:46 AM
sblvro's Avatar
repost
Old Sep 15, 2005 | 02:07 PM
Dan_EVO's Avatar
Yea this has been posted before, I don't think it will hurt the evo IX engine at all.
Old Sep 21, 2005 | 07:59 AM
Sschmuve1's Avatar
From the Singapore Brochure thread.
"Detail improvements have been made to
increase engine durability and reliability.
The addition of intake temperature and
pressure sensors in the intake manifold
has raised air/fuel charge flow and
ignition timing precision."
Now won't these sensors be another hurdle for tuners? For instance...You install a blow off valve that doesnt open and shut exactly like oem. The new manifold pressure sensor picks that up, and Ding a stupid CEL. Thanks.
Old Sep 21, 2005 | 08:03 AM
Fireball's Avatar
That's why I always have said, if you plan to tune, or modify your car, the VIII is the way to go.
If you're just going to buy it, drive the crap outta it and not change anything, the IX is the way to go.
Old Sep 21, 2005 | 08:30 AM
outsider's Avatar
More obstacles to overcome... it will just take awhile longer (I believe) to mod the IX due to the new technology being added on to it... the 4G63 has been the way we know it for many years now... eventually the MIVEC 4G63 will surpass our level of modification, but not without some hiccups along the way.
Just my thoughts.
Old Sep 21, 2005 | 08:56 AM
Reducer's Avatar
Just my thoughts.
Is Mitsubishi going to use a whole new motor for the X? If so, I'd have to think that the tuners wouldn't be very interested in waisting to much time learning the quirks of a technology that was only used for one year in the Evo?
Old Sep 21, 2005 | 12:54 PM
outsider's Avatar
I don't think anyone has a definite answer on this yet... I personally hope not, but they might go into a whole new platform given the whole EVO X thing... 10th gen and all...
Old Sep 21, 2005 | 12:56 PM
Cajun Power's Avatar
put an EVO 8 ECU on the EVO 9. Screw Em!
Old Sep 23, 2005 | 08:00 AM
jid2's Avatar
Best Motoring is not relative for USDM cars. I doubt that the USDM 9's will have those changes. The JDM MR has all sorts of changes to the engine over the standard 8, most apparent is a metal BOV. Does the USDM MR have a metal BOV...NO!
Where is the AYC??? Not on the USDM car. Where is the Rear Aero bumper??? Not on the USDM cars. I would bet that the 9's have the Mivec head, the new turbo and that's it.
Old Sep 24, 2005 | 12:07 AM
Hotshot940's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=158233
Old Sep 24, 2005 | 12:11 AM
BBYBruno's Avatar
Evo IX for Dummies!
The stupidity is giving me a headache. Please everybody read this and I hope you come out with some factual knowledge.
Originally Posted by HotShot940
MIVEC strikes fear into the hearts of tuners and enthusiast worldwide
Old Oct 5, 2005 | 02:09 AM
boomtown's Avatar
Most people running standalone engine management convert from MAF to MAP sensor anyway - that way you can delete the entire MAF structure and run a 3'' hardpipe plus whatever intake strikes your fancy (Yes I know you blokes are addicted to your flashes...)
If you have an atmo BOV mounted before the MAP sensor it will actually reduce CELs. MAFs and BOVs dont mix well. So Mitsi is doing you a favour.
cerevo
12
Sep 9, 2016 03:45 AM
Igaly1021
Aug 15, 2016 07:56 PM
wreckleford
Apr 19, 2016 08:00 AM
real fast
Mar 9, 2016 09:45 AM
project95gsx
Jun 1, 2009 11:08 AM
