IX headlamps up close
Old Oct 14, 2005 | 06:44 AM
dzuest's Avatar
Originally Posted by Z1 Performance
they require a ballast and a bulb...that's it. At best it weighs 5-10 lbs total
^ exactly. Two bulbs that are specially made to burn the Xenon gas and two ballists that are small rectangles, 6"x3"x2".
here's more info...
https://www.evolutionm.net/forums/sh...d.php?t=131680
Old Oct 14, 2005 | 06:48 AM
EVO8 WHOA's Avatar
oki have a box here with 8 McCulloch Ballasts in it and it prolly only weighs 15 lbs and those are high quality ballasts and the bulbs are in the oz.'s... just like any other bulb really.
Old Oct 14, 2005 | 06:49 AM
EVO8 WHOA's Avatar
15lbs with a short shifter thing, all those brass shifting bushings and a ss clutch line too lol. just a miscellaneous box of parts...
PurgeIt's Avatar
Eh, I've used CATZ HIDs in several cars and they don't weigh much at all. With the ballast, ignitor and bulb, I'd say 5lbs per side max. Too bad DOT made aftermarket HIDs illegal....
Old Oct 14, 2005 | 07:04 AM
res04's Avatar
Unless your Evo is track only dont worry about 18lbs of HID lamps hanging over the front. 999/1000 wont be able to tell the difference with or without them.
Want to lose weight? Grab a buschur exhaust and swap out the factory brace with a DC Ti unit.....theres 20 lbs saved and then some.
Old Oct 14, 2005 | 07:08 AM
AWDTurbo4's Avatar
yup this past weekend I ran from a 13.5 and now 12.1...
my only mod, took off the HIDs
Old Oct 14, 2005 | 07:26 AM
res04's Avatar
I think the 18-20 or so lbs is the entire lamp assembly, ballast / igniter, bulb...this may include the up/down lamp adjuster motors which surely add some weight.
Bulb + Ballast = not much weight at all on their own.
Old Oct 14, 2005 | 07:28 AM
EVO8 WHOA's Avatar
ya those things are heavy as ****. i had to carry a set of mr heads n tails to the bodyshop the other day. u remove both headlights yur saving like 40lbs!
gqpenguin
Feb 4, 2017 05:50 PM
raidokoiv
Apr 7, 2013 03:17 AM
omniprobe
Jun 5, 2010 06:46 PM
rd122481
Nov 24, 2009 11:38 AM
unclecomfort
Jul 29, 2008 08:34 AM
