4B11 Engine in EVO X bye bye 4g63
Old Sep 28, 2007 | 09:48 AM
Evozster's Avatar
this is a repost of a repost of a repost of the original repost of the first post......GET A GRIP, NO MORE 4G63, IT'S DEAD, OVER, CROAKED, NADA, ENDED.....In the immortal words of Dr. Phil: GET OVER IT!!!!!
Old Sep 28, 2007 | 09:55 AM
EVOM3's Avatar
There's an Evo X coming out?
Old Sep 28, 2007 | 10:33 AM
91TB78's Avatar
What's an "Evo?"
Old Sep 28, 2007 | 10:39 AM
saiyanzzrage's Avatar
whats a 4g63?
and to the OP, kill yourself
Old Sep 28, 2007 | 10:57 AM
Evoryder's Avatar
EVo X = AutoX?
Old Sep 28, 2007 | 06:08 PM
lemmonhead's Avatar
micheal jackson has a plastic face
is it really true that micheal jackson has plastic surgery on his face, no way!!
Old Sep 28, 2007 | 06:20 PM
jackygor's Avatar
Old Sep 28, 2007 | 07:11 PM
FL_SilverEvo8's Avatar
can someone say motor swap 4b11t to a 4g63. posablie?
Old Sep 28, 2007 | 07:19 PM
CGK's Avatar
CGK
Can you send the TPS reports ASAP???
Old Sep 28, 2007 | 08:22 PM
felickz's Avatar
OMFG did you hear they replaced the 6mt with an AUTO omfg omfg omfg omfg
I am a member of an EVO community and i just found this out
Old Sep 30, 2007 | 04:44 PM
zeckgx's Avatar
Wow all i hear is a bunch of crying about an old iron block going away and how ugly the car looks. news flash Mitsubishi hasn't been in the black for years if they make a car that the dumb public will buy they make more money which is all any one cares about anymore. as for the block Subaru's block is aluminum, ferraris block is aluminum, I think its about time Mitsubishi moved out of the stone age. The gripe about the design of the block is ridiculous It is a joint venture of dcx, mitsu and hayundi for just the block the top end, pistons, and main bering is all different for each company so a lighter moter making the same HP sounds awesome to me.
Old Sep 30, 2007 | 05:56 PM
nongan's Avatar
Mitsu die-hards are not as literate as the subie die-hards. There is way less
misspelling on nasioc.
Old Sep 30, 2007 | 06:04 PM
derangedazn's Avatar
Same thing can be said about fast stis compared to fast evos.
Good thing I own a camry instead.
Old Oct 1, 2007 | 10:11 AM
Canexican's Avatar
The argument with people *****ing about the aluminum block is certainly warranted. Yes, the fact that other manufacturers use aluminum blocks may be true, that doesn't necessarily mean that it is superior. It is lighter, but it is ultimately not as durable as iron.
The name in the auto-manufacturing game is cost cutting, which is why they are making this aluminum "World Engine" move with the collaboration of DCX and Hyundai. But cost-cutting in the engine dept. doesn't necessitate longevity. I'm sure it will run fine for a stock motor running 20-21 lbs of boost, but I think most people on this forum are ultimately concerned with how the engine will respond to modification and the increase of boost pressure. I doubt you will see many high horsepower (500awhp & up) 4b11t evo's due to the aluminum block. You can basically forget 8 and 9 sec. runs on that motor as well.
My biggest gripe is keeping it a 2.0ltr when they aren't even a WRC contender anymore. Increasing displacement would allow for less boost, and ultimately less strain on the block, to make the same power. I really do hope the 4b11t proves to be as bullet-proof as the 4g63, but I suppose only time will tell.
Old Oct 1, 2007 | 10:15 AM
whats an evo x? i thought the evo 10 was the next evolution? and what happened to evos a - w?
