EVO X IHI turbo Info
Old Oct 17, 2007 | 12:02 PM
BOOSTEZ's Avatar
EVO X turbo Info
All:
I thought I'd start this thread and hopefully over time we'll get more information about this turbo. Anyone have any real specs on it? Flow charts? Maximum boost pressure? Comparison to the EVO VIII/EVO IX turbos?
-M
Old Oct 17, 2007 | 12:20 PM
syr00's Avatar
Hmm maybe, some people in Japan can get more info since there selling there allready!
Jeez if I lived in Japan I'd have a whole gallery of pics and info to post..
You know.. not just the same TYPES OF PICTURES
-ACTUAL DEALER COST, INCLUDING MARKUP
-VIDEOS
-BETTER PICTURES OF THE BROCHURE
-TRANSLATE THE BROCHURE
-GO ON A TEST DRIVE
Old Oct 17, 2007 | 12:28 PM
Dosagex's Avatar
It's Japan what do you expect???
Old Oct 17, 2007 | 12:32 PM
tvbf1's Avatar
Is it really a 15G turbo? I heard that it's 15 and the markings on the turbo did say 15.
Old Oct 17, 2007 | 01:01 PM
NurSpecSupport's Avatar
Here is a link to the turbine. wallpaper quality
http://www.seriouswheels.com/2008/kl...r-1024x768.htm
Old Oct 17, 2007 | 01:10 PM
BOOSTEZ's Avatar
No. It's not a Mitsu turbo. It's a Warner IHI turbo. Same make on the Mazdas.
-M
Old Oct 17, 2007 | 02:02 PM
dimviii's Avatar
somebody had post the type of the turbo which is TD05H-152G6-12T ...
this is a mitsubishi turbo not an ihi...
Old Oct 17, 2007 | 02:08 PM
"We looked, and there's plenty of space in there for larger turbos once the stock TD05H-152G6-12T is maxed out."
source: http://www.edmunds.com/insideline/do...leId=122744#21
It doesnt say who makes it, but it confirms the post above regarding the model/part number for the turbo.
Old Oct 17, 2007 | 02:14 PM
cpoevo's Avatar
-M
Warner and IHI are 2 different companies. Borg Warner bought out KKK, and is based in Europe. IHI is based in Japan.
Old Oct 17, 2007 | 03:05 PM
BOOSTEZ's Avatar
You are partially correct - they did merge..
"IHI Turbo America (ITA) was founded in 1980 as Warner-Ishi Corporation a 50/50 joint venture between IHI and Borg Warner Automotive and a licensee of IHI turbocharger technology."
http://www.ihi-turbo.com/companyinfo.htm
Old Oct 17, 2007 | 03:11 PM
BOOSTEZ's Avatar
Hmm.. this is interesting.
I'll change the title of the thread then. A 15G is certainly not going to put out more power than the stock 16G-type turbo that came with the last generation.
-M
Old Oct 17, 2007 | 06:37 PM
jetmn's Avatar
-M
If you knew what the 15g stood for, you would know that it very well may flow more and be smaller diameter. The exhaust side is bigger.
Old Oct 19, 2007 | 11:17 PM
BOOSTEZ's Avatar
Flowing more on the exhasut is only half of the equation. There's no use in having a larger hot side and a smaller compressor wheel. Airflow will still be restricted.
-M
Old Oct 20, 2007 | 09:13 PM
jetmn's Avatar
-M
If you read what I said you would see I was talking about the compressor side. Just because the compressor wheel is slightly smaller diameter, that doesn't mean it will flow less. We are only talking about a 5% diameter change, but if the wheel is wider or has better blades, it may still flow more. Only time will tell, but this should be another great stock turbo. The Japanese literature said it flowed 14% more than the IX turbo did.
Old Oct 20, 2007 | 09:47 PM
Jadiem's Avatar
what does it matter who makes it? a TD05 blah blah blah turbo is different if IHI or Mitsu makes it?
i think the X will run a slightly larger turbo, but less boost than the 8's and 9's
