Just upgraded to firmware 1.7 help
Originally Posted by V8 HUNTR
Guys,
I am having the same problem with the UTEC hiccup after upgrading to the new 1.7 firmware. Its a strange feeling, allmost like the car is pulling an assload of timing around 3-5k rpm's. Also, in fifth gear, the car detonates pretty bad. Im not the most computer literate person, and am kindof timid when it comes to messing with my UTEC. What should i do ???? My mods are, UTEC, Intake, Turbo Back Exaust and fuel pump.
Thanks,
Taylor
Thanks,
Taylor
just make sure that you save your current settings so you can go back if things dont work out. I had set the timing back to ECU for the 0-40% and was depressed for a little loss of power so I reentered the values back in and am taking it easy on the car until I can get some more feedback on the maps.
