calling all s-afcII need help please
just got done putting in my afcII in my evo everything seems fine all the wiring is done and the setting too did not start the car until i put the setting in then when it came to set the knocking signal setting i had to start the car but it will not start my bat is 12.7 V but iys not startting . one more thing in the setting main menu #1 hi-thrtl is set but #2 lo-thrtl i do not what to do with it do i put the same setting as in hi-thrtl what do i do
Sounds like you may have a wire switched somewhere or your ECU may not be plugged in all the way. Double check all your wiring to make sure it's all correct. I checked mine 3 times and I found mistakes which caused my CEL to come on.
I have my hi-throttle at 65% and lo-throttle at 30%.
What settings are you trying to use?
