po234 fuel cut?
po234 fuel cut?
I pulled the code:
DTC P0234: Turbocharger Wastegate System Malfunction
I recently installed a walbro 255 and 264/264's.
Any ideas for S-afc settings or alterations to buschurs stage 2?
Possibly some colder plugs for starters?
MODs are:
MAF induction pipe INJEN kit w/ upper I.C. piping & Forge D.V.
Boost set to ~20 w/Halman pro rx
Full 3" Turboback
MODs are:
Full 3" Turboback
when you connected you Boost Controller did you disconnect & remove the stock Boost control solenoid?
if its not left in the car with the connector plugged in it will throw a code.
The stock boost controller is still plugged in, but capped off, and I had a P.E. boost controller before with no problems. It statically charged and shorted on me however.
A fuel cut come from too lean or rich? My Karman was close to 1700.
FS[MidWest]: Test pipe, temp gauge, gauge holders
turbotaloon95
Midwest Region
Apr 18, 2016 09:33 AM
turbotaloon95
Apr 18, 2016 09:32 AM
jessem220
Oct 3, 2013 11:07 PM
evo 8 ya
Feb 24, 2005 09:13 AM
