Colant temp 96c is it okay ? using Power FC
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
The newer versions lower the fan to 85 degrees. Apex insists that the original setting (100 degrees I think) isn't a problem. I am not an engineer and can't argue the point, but they are not in the business to blow up cars and are one of the bigger jdm parts houses.
They should change yours if you send it to them, but it may take a while. I sent mine in and had it lowered. I live in Texas and would rather be safe.
Originally Posted by talalhz
Hi, I have the Apexi Power FC on my 05 MR. Is there a way to control when the fan ckicks in ?
I'm not sure about the Apex Power FC. But coolant temp should be lower than 205 degrees Fahrenheit. Thats high for the fan to be set at .
96 celsius= 205 fahrenheit.
85 celsius would be more like it which is 185 Fahrenheit
I think that the fan should be set to turn on at 180 or 185 fahrenheit.
Thats just my opinion.
Derek
Derek888
53
Mar 15, 2011 07:17 PM
h22gordo
Apr 1, 2008 09:30 PM
robertrinaustin
10
May 27, 2006 11:55 PM
96c, coolant, evolutionm, fahrenheit, fan, farenheight, farenheit, fc, fc3s, jdmspeccom, power, temp, temperature, temps
