5k rpm studder with UTEC
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
I found something very odd. The percentage change of the maf doesn't match up with the dyno a/f. The dyno shows that it's going rich right after 4k but on the map and logs it shows that it's taking away fuel at 4k. It would be nice if you had a tuner pro to borrow and correlate airfuel to the logs aswell. I was going to suggest some changes, but when i saw the dyno, i don't know if that rich spot was caused by the string of "+3.2's" or if the dyno wb is late or whatever.
im going to datalog after work tomorrow with a LM wideband. its not the tuner, but it will show what my afr is. i was planning on getting the tuner pro before this all happened.
It may be something that I don;t know, but I just want to bring it up.
the scaling isn't very good with larger injectors, so i was told to run it like that from a fellow member. and it seems to work the best right now.
i just changed my spark plugs again, and im going to flash my ecu to stock and change out my 780cc for the stockers. im going to run map 0, then run a moddified map for cams and stock injectors. if the utec works correctly, i will be replacing the injectors.
probably some denso/greddy 680cc or 720cc. or the FIC 750cc.
probably some denso/greddy 680cc or 720cc. or the FIC 750cc.Like I said, I know much about UTEC yet, but I am just speaking from my other EMS experience.
Originally Posted by BJai02
I may be mistaken, but if you set your injectors to 600cc and you actually running 780cc, doesn't it makes the ECU thought it's a smaller injectors and make your car goes too RICH in close loop? It might true during initial throttle tip in, and the ECU is adjusting the fuel in close loop.
Most of it is due to the slow injector on times.
Thanks,
Jermaine~
Originally Posted by Imprezd
Have you tried to lean out the area in question yet. I mean after all if it is going rich try and lean it out.
Thanks,
Jermaine
Thanks,
Jermaine
