5k rpm studder with UTEC
Old Jan 12, 2005 | 01:44 PM
  #76
VTECH8TR's Avatar
Originally Posted by BSREVOLUTION
i wasn't able to change the injectors today, but i did get the ecu reflashed to stock. not the car is running a ton better. im going to wait to tune until i get a tuner.
Justin,
Cool i am glad we pinpointed the problem. When you sent me the email about your ecu being flashed, i literally jumped off my seat and called you. Shoot me an email or call me.
Lu
Old Jan 12, 2005 | 04:50 PM
  #77
TampaTurbo's Avatar
BSREVOLUTION,
There was another thread /poll in here about dynoflashes of somekind in combo with the UTEC. The majority of people had problems including me. I got the p0300 relash and it was like wow...that made a difference. Good to see you feel it running better. Let us know on the tuning once again.
Old Jan 12, 2005 | 05:22 PM
  #78
BSREVOLUTION's Avatar
sure thing. im getting the pro and getting smaller rc 750cc. and hoping everything is cleared up. i want to go back to the dyno, but i dont want to make that two hour trip for nothing again. ill let everyone know what happens. jc
Old Jan 17, 2005 | 10:05 PM
  #79
rraulston's Avatar
Mine is doing it now also. This is a 1-2-3 shifting log. In third you can see the rpm waver!!! this is pissing me off.......
Code:
     	     	     	   	Load	Knock	      	      	 Mod	  Mod	      	  Mod	  WB
 RPM	  MAP	  MAF	TPS	Site	Count	 Ign#1	 Inj#1	 Ign	  Fuel	Boost	  MAF	  AFR
    	  psia	  Hz	 % 	    	     	  deg 	 duty 	 deg	   %  	(OL) 	   Hz
859	27.6	38	0	0	0	3.2	1.6	ECU. 	0	ECU.  	37	14.61
863	27.6	38	0	0	0	5.1	1.6	ECU. 	0	ECU.  	41	14.61
818	27.6	38	0	0	0	3.2	1.5	ECU. 	0	ECU.  	38	14.58
856	27.6	38	0	0	0	4.8	2	ECU. 	0	ECU.  	39	14.7
819	27.6	38	0	0	0	3.2	1.4	ECU. 	0	ECU.  	37	14.78
894	27.6	38	0	0	0	4.2	1.4	ECU. 	0	ECU.  	38	14.65
873	27.6	38	0	0	0	4.2	1.6	ECU. 	0	ECU.  	36	14.58
907	27.6	37	0	0	0	3.2	1.4	ECU. 	0	ECU.  	37	14.49
1975	27.4	169	20	0	0	29.2	6.2	ECU. 	0	ECU.  	180	14.49
2009	27.4	172	20	0	0	29.2	4.9	ECU. 	0	ECU.  	169	14.49
2142	27.4	208	22	0	0	29.2	14.1	ECU. 	0	ECU.  	243	14.42
2287	27.4	282	48	10	0	18.4	10	ECU. 	0	ECU.  	270	14.58
2440	27.4	309	59	10	0	17.2	11.2	ECU. 	0	ECU.  	374	14.08
2620	27.4	348	65	10	0	18.4	12.3	ECU. 	0	ECU.  	323	12.59
2898	27.4	414	75	10	0	18.5	15	ECU. 	0	ECU.  	468	11.68
3121	27.4	486	84	10	0	18.2	17.3	ECU. 	0	ECU.  	545	11.49
3360	27.4	553	84	10	0	16.4	20.5	ECU. 	0	ECU.  	718	11.33
3687	27.4	726	85	10	0	13.7	24.8	ECU. 	0	ECU.  	612	11.24
3977	27.2	826	85	10	0	10.7	32.4	ECU. 	-0.1	ECU.  	936	11.05
4345	27.2	1106	86	20	0	8.6	44.8	ECU. 	-1	ECU.  	1016	10.56
4734	27	1453	86	30	0	6	58	ECU. 	-1.3	ECU.  	1315	10.05
5151	27.2	1661	93	50	0	6.1	63	ECU. 	-2.9	ECU.  	1582	9.68
5473	27.4	1689	93	70	0	7.2	66.7	ECU. 	-1	ECU.  	1666	9.68
6082	27.2	1773	96	80	0	12.2	69.8	ECU. 	-2	ECU.  	1824	9.83
6459	27.2	1811	97	90	0	15.5	69.6	ECU. 	-4	ECU.  	1760	9.87
6930	27.4	1865	97	100	0	19.4	72	ECU. 	-4	ECU.  	1724	10.02
7002	27.4	576	28	0	0	37.5	22.3	ECU. 	0	ECU.  	123	10.21
6472	27.4	156	1	0	0	38.5	8.9	ECU. 	-0.5	ECU.  	162	11.49
6016	27.4	524	22	0	0	34.4	21.3	ECU. 	-1	ECU.  	710	13.31
4830	27.4	897	84	10	0	16.8	35.1	ECU. 	-1	ECU.  	980	13.39
5192	27.4	1243	100	10	0	12.1	52.4	ECU. 	-1	ECU.  	1141	11.45
5216	27.2	1344	100	30	0	10	57.8	ECU. 	-1	ECU.  	1302	10.06
5291	27.2	1661	100	50	0	7.2	67.6	ECU. 	-2.4	ECU.  	1677	10.09
5500	27	1706	100	70	0	6.2	69.6	ECU. 	-1	ECU.  	1724	9.9
5777	27.2	1694	100	80	0	10.2	68.9	ECU. 	-2	ECU.  	1760	9.64
6060	27.2	1730	100	90	0	12.3	66.9	ECU. 	-4	ECU.  	1655	9.86
6265	27.2	1805	100	100	0	14.5	68.4	ECU. 	-4	ECU.  	1712	10.11
6497	27.2	1805	100	100	0	16.3	68.6	ECU. 	-4	ECU.  	1689	10.23
6693	27.2	1845	100	100	0	18.3	70.9	ECU. 	-4	ECU.  	1773	10.3
6887	27.4	1838	100	100	0	19.6	71.5	ECU. 	-4	ECU.  	1773	10.36
7168	27.4	1851	87	100	0	21.4	72.7	ECU. 	-4	ECU.  	1760	10.36
6887	27.2	145	1	0	0	38.5	8.5	ECU. 	0	ECU.  	130	11.08
6337	27.2	187	1	0	0	38.6	9.8	ECU. 	-1	ECU.  	163	12.81
5583	27.2	847	67	10	0	27.4	32.5	ECU. 	-1	ECU.  	862	13.92
5402	27.4	1068	100	10	0	16.1	45.6	ECU. 	-1	ECU.  	1184	12.83
5265	27.4	1396	100	10	0	11.1	59.1	ECU. 	-1	ECU.  	1543	10.96
5428	27.4	1557	100	40	0	8.4	65.9	ECU. 	-1	ECU.  	1515	9.99
5385	27.2	1700	100	60	0	6.7	66	ECU. 	-3.5	ECU.  	1488	9.92
5473	27.2	1683	100	80	0	7.4	67.1	ECU. 	-2	ECU.  	1644	10.04
5611	27.4	1650	100	90	0	9	68.6	ECU. 	-4	ECU.  	1655	9.99
5717	27.4	1730	100	90	0	10.2	69.5	ECU. 	-4	ECU.  	1655	10.01
5797	27.4	1683	100	90	0	9.9	67.1	ECU. 	-4	ECU.  	1677	9.99
5941	27.4	1730	100	90	0	12.3	68.9	ECU. 	-4	ECU.  	1592	10.05
6082	27.4	1760	100	100	0	13.4	69.9	ECU. 	-4	ECU.  	1562	10.15
6184	27.2	1773	100	100	0	14.3	70.3	ECU. 	-4	ECU.  	1689	10.15
6265	27.2	1779	100	100	0	14.4	70.8	ECU. 	-4	ECU.  	1689	10.15
6361	27.4	1805	100	100	0	15.5	71.9	ECU. 	-4	ECU.  	1677	10.15
6459	27.4	1818	100	100	0	16.4	71.2	ECU. 	-4	ECU.  	1655	10.2
6548	27.4	1824	100	100	0	16.3	72.8	ECU. 	-4	ECU.  	1748	10.23
6640	27.4	1805	100	100	0	18.3	72.4	ECU. 	-4	ECU.  	1785	10.2
6720	27.4	1818	100	100	0	18.6	72.1	ECU. 	-4	ECU.  	1760	10.2
6816	27.4	1845	100	100	0	19.6	73.7	ECU. 	-4	ECU.  	1798	10.2
6887	27.2	1851	100	100	0	20.8	73.8	ECU. 	-4	ECU.  	1773	10.17
7017	27.4	1872	100	100	0	21.7	73.8	ECU. 	-4	ECU.  	1760	10.21
7107	27.2	1858	100	100	0	21.5	73.9	ECU. 	-4	ECU.  	1773	10.24
I hope you can read this. i still cant figure out how to posts these logs right.....RRR
Old Jan 17, 2005 | 10:09 PM
  #80
bbbwrx's Avatar
Code:
Looks like you fuel is jumping right there. Check your map and smooth it out a little bit in that area. I think this could be causing your problem.
Ben
  #81
rraulston's Avatar
If i cant figure this out, my new gt-35r was a waste of money. The 550cc's wont be enough fuel. I will be leaning alot more out tommarrow and re-logging.
Old Jan 17, 2005 | 10:11 PM
  #82
rraulston's Avatar
you know whats weird Ben, i have no 3.5 in the map!! only 1,2,3 or 4. Where the heck did the 3.5 come from??!!
Old Jan 17, 2005 | 10:17 PM
  #83
bbbwrx's Avatar
I know alot fo people have had trouble tuning the UTEC with a GT35r. Alot of people have had to switch to the the AEM for speed density. It is posible the UTEC is averaging something in your map to get that 3.5. What is in your map at 5-5500 in 40 60 and 80 load points. Or if you don't mide post up you whole map.
Ben
Old Jan 17, 2005 | 10:30 PM
  #84
rraulston's Avatar
here is my just started fuel map:
Code:
 RPM  0%    10%   20%   30%   40%   50%   60%   70%   80%   90%   100%
  500 0     0     0     0     0     0     0     0     0     0     0
  750 0     0     0     0     0     0     0     0     0     0     0
 1000 0     0     0     0     0     0     0     0     0     0     0
 1250 0     0     0     0     0     0     0     0     0     0     0
 1500 0     0     0     0     0     0     0     0     0     0     0
 1750 0     0     0     0     0     0     0     0     0     0     0
 2000 0     0     0     0     0     0     0     0     0     0     0
 2250 0     0     0     0     0     0     0     0     0     0     0
 2500 0     0     0     0     0     0     0     0     0     0     0
 2750 0     0     0     0     0     0     0     0     0     0     0
 3000 0     0     0     0     0     0     0     0     0     0     0
 3250 0     0     0     -2    0     0     0     0     0     0     0
 3500 0     0     0     -3    -2    0     0     0     0     0     0
 3750 0     0     -2    -4    -4    -2    -1    0     0     0     -4
 4000 0     0     -2    -4    -4    -4    -1    0     0     0     -4
 4250 -1    -1    -1    -3    -4    -4    -2    -1    -1    -4    -4
 4500 -1    -1    -1    -2    -4    -4    -3    -2    -1    -4    -4
 4750 -1    -1    -1    -1    -2    -4    -4    -2    -1    -4    -4
 5000 -1    -1    -1    -1    -1    -3    -4    -2    -2    -4    -4
 5250 -1    -1    -1    -1    -1    -3    -4    -2    -2    -4    -4
 5500 -1    -1    -1    -1    -1    -2    -3    -1    -2    -4    -4
 5750 -1    -1    -1    -1    -1    -1    -3    -1    -2    -4    -4
 6000 -1    -1    -1    -1    -1    -1    -3    -1    -2    -4    -4
 6250 -1    -1    -1    -1    -1    -1    -2    -1    -2    -4    -4
 6500 0     0     0     0     0     0     0     0     -2    -4    -4
 6750 0     0     0     0     0     0     0     0     -2    -4    -4
 7000 0     0     0     0     0     0     0     0     0     -4    -4
 7250 0     0     0     0     0     0     0     0     0     -4    -4
 7500 0     0     0     0     0     0     0     0     0     -4    -4
 7750 0     0     0     0     0     0     0     0     0     0     -4
 8000 0     0     0     0     0     0     0     0     0     0     -4
 8250 0     0     0     0     0     0     0     0     0     0     0
 8500 0     0     0     0     0     0     0     0     0     0     0
 8750 0     0     0     0     0     0     0     0     0     0     0
Yea, i see it too. I start in the 100% and work my way in. 18 pounds boost 100 octane. I like good fuel when tuning. A little insurance. Today was just trying to get 11 AFR and ran out of time. I still think my stumble at WOT is more that 1 or 2 % in fuel....
Old Jan 17, 2005 | 10:39 PM
  #85
bbbwrx's Avatar
It looks like it was averaging the fuel map from 60% 5250 and one of the 80% -2 Look like it might need a little more smoothing. I would just work on the AFR and then once your map is set up try and smooth it out if it is still happening.
Ben
Old Jan 18, 2005 | 04:15 AM
  #86
MalibuJack's Avatar
The UTEC "Tweens" cells, in other words, if the RPM is somewhere between two cells, or between two load sites, you'll see it.. But between load site cells the values are generally very close so you'd typically not see that.
Old Jan 18, 2005 | 04:25 AM
  #87
MalibuJack's Avatar
Yeah your going to have to smooth that map a bit so it doesnt suddenly jump value between cells.. you'll "Clean" up alot of your drivability glitches doing that.. especially if you are "Skipping" load sites due to really fast airflow ramping..
The biggest problem with big turbos and the UTEC, really isn't the UTEC, its the MAF.. the very high airflow rate seems to be troublesome with the stock MAF.. plus you have to deal with the factory ECU's "Learning" of the tip-in throttle which takes some time to adapt. A big turbo is just troublesome for any MAF based solution, you end up with needing to run higher idle to increase vacuum, especially if you have cams.
I definitely recommend doing some research on a blowthrough setup if you have a big turbo since going to a standalone just to get speed density features isn't always the best way to go if you don't want to spend umpteen hours making minor adjustments for drivability.
Personally, when I see the tradeoffs people make when they go with a big turbo, I feel more and more comfortable with my decision to stick with stock-ish turbo setups.
Anyway, it *IS* possible to get everything to work well, it just takes time, the biggest thing that happens is that you tune the car, and feel the drivability is terrible, but we forget that it takes a day or two of driving to get the ECU to relearn the changes and for the drivability to "come back" on a standalone you would be making these adjustments manually.
Old Jan 18, 2005 | 07:11 AM
  #88
Imprezd's Avatar
Ray,
I just returned to work in observation of the Good Ol Reverend Martin Luther King.
Looks like you are having some issues with your fuelling. As well, have you forgotten about my recommendation to use a map sensor for load with larger turbochargers. This will allow you to have a smoother transition through load sites and keep you from getting all pissed off. Also it should be noted that by boss drives the Evo with the GT35r with the maf in the stock position every day and he loves it. Also your max hz for mapping is way too low. 1800hz on a gt35r is nothing. If you bump your max to a higher number you'll have slower transitions through load sites as well.
Good Luck with Tuning Bro.
Thanks,
Jermaine~
P.S. Remember tuning isn't always easy!
Old Jan 19, 2005 | 08:09 PM
  #89
hey guys, just wanted to report that i just installed my rc 750cc injectors and the car is running a hundred times better. the car is pulling very hard and all the knock is gone. there is still a bit of a stumble when the gas is pressed down quickly. but i think it can be fixed with a good tune. i really want go back down to harman and see if they can help me out with another tune. im going to log a run or two tomorrow. im so happy. late justin
Old Jan 19, 2005 | 10:10 PM
  #90
rraulston's Avatar
can you elaborate on the injector issue??? My new injectors are 780cc from precision turbo. RRR
