UCC Question
Old Jan 11, 2005 | 02:49 PM
EvoTech's Avatar
UCC Question
For those using UCC I have a question. Today I uploaded a new map to MAP 2 in the UTEC. Then I went into hyperterminal and it did not show any information about MAP 2. It was as it was not even there. Any ideas.
Old Jan 11, 2005 | 03:03 PM
SoR's Avatar
SoR
Are you sure you uploaded it?
It works fine for me but it doesn't work if your COM port is in use by something else (hyperterm) or if your car is running.
MalibuJack's Avatar
If you upload a map without a "comment and label" it will look blank or "nonexistent" because its title and comment are null values.. I discovered that after I uploaded a new map I created and didn't edit its name or comments..
Old Jan 11, 2005 | 03:38 PM
EvoTech's Avatar
That sounds about right. I did not include a comment or name it. I will try it with a name in the A.M.Thanks
