First logging run
Old Jan 14, 2005 | 02:27 PM
dryad001's Avatar
First logging run
This was all done in 3rd gear, about 17psi because of the cold.
2076 +27.0 214 100 10 00 +16.1 10.5 ECU. +0.0 ECU. 212
2129 +27.0 262 100 10 00 +17.1 11.4 ECU. +0.0 ECU. 253
2156 +27.0 270 100 10 00 +15.1 11.8 ECU. +0.0 ECU. 273
2249 +27.0 272 100 10 00 +12.3 13.5 ECU. +0.0 ECU. 236
2308 +27.0 288 100 10 00 +12.3 16.1 ECU. +0.0 ECU. 388
2422 +27.0 314 100 10 00 +10.2 16.3 ECU. +0.0 ECU. 304
2469 +26.8 414 100 10 00 +7.5 17.7 ECU. +0.0 ECU. 496
2568 +26.8 334 100 10 00 +6.5 20.6 ECU. +0.0 ECU. 570
2647 +26.8 667 100 10 00 +4.5 23.8 ECU. +0.0 ECU. 452
2761 +26.8 759 100 10 00 +1.7 30.5 ECU. +0.0 ECU. 503
2876 +26.8 754 100 10 00 -1.7 36.2 ECU. +0.0 ECU. 631
2986 +27.0 691 100 10 00 -1.3 40.9 ECU. +0.0 ECU. 862
3115 +27.0 862 100 10 00 +2.7 41.2 ECU. +0.0 ECU. 606
3258 +27.0 917 100 20 00 +2.7 42.5 ECU. +0.0 ECU. 907
3380 +26.8 902 100 20 00 +4.0 42.1 ECU. +0.0 ECU. 805
3546 +26.8 880 100 20 00 +4.3 45.1 ECU. +0.0 ECU. 719
3667 +26.3 810 100 20 00 +4.3 49.8 ECU. +0.0 ECU. 840
3818 +26.3 776 100 20 00 +5.6 49.8 ECU. +0.0 ECU. 1106
3977 +26.6 797 100 20 00 +5.7 54.9 ECU. +0.0 ECU. 994
4120 +26.6 883 100 30 00 +5.8 53.4 ECU. +0.0 ECU. 950
4295 +26.8 919 100 30 00 +6.9 56.1 ECU. +0.0 ECU. 925
4391 +26.8 860 100 30 00 +6.8 55.9 ECU. +0.0 ECU. 838
4522 +26.6 1165 100 40 00 +5.8 56.8 ECU. +0.0 ECU. 1077
4668 +26.8 1201 100 40 00 +6.9 59.8 ECU. +0.0 ECU. 1216
4852 +26.6 990 100 40 00 +7.1 66.6 ECU. +0.0 ECU. 1256
4938 +26.8 1253 100 40 00 +8.1 66.8 ECU. +0.0 ECU. 998
5096 +27.0 1259 100 50 00 +8.2 70.4 ECU. +0.0 ECU. 1179
5224 +26.8 1108 100 50 00 +8.3 71.3 ECU. +0.0 ECU. 1275
5333 +27.0 1187 100 50 00 +6.1 74.0 ECU. +0.0 ECU. 1165
5473 +26.8 1315 100 50 00 +7.3 77.7 ECU. +0.0 ECU. 1231
5602 +27.0 1392 100 60 00 +8.3 78.7 ECU. +0.0 ECU. 1322
5747 +26.8 1269 100 60 00 +9.2 78.9 ECU. +0.0 ECU. 1440
5847 +26.8 1336 100 60 00 +10.1 81.0 ECU. +0.0 ECU. 1262
5995 +26.8 1396 100 60 00 +11.3 85.0 ECU. +0.0 ECU. 1420
6105 +26.6 1377 100 60 00 +11.4 85.5 ECU. +0.0 ECU. 1385
I will be doing some AFR runs as soon as the tuner gets calibrated
Old Jan 14, 2005 | 02:56 PM
SoR's Avatar
SoR
I didn't do the free air calibration when I first got my sensor, on idle it shows 14.6-14.8 which seems correct so I didn't bother. Should I still do it?
Old Jan 15, 2005 | 09:24 AM
Widebandphillip's Avatar
Here's a little trick if you can calibrate the 02 while the car is moving. Go in 4th or some high gear and go up to some mid rpm and then let off the throttle until the ecu engages dfco. Then you can calibrate your 02 sensor while it's still in your bung.
Old Jan 15, 2005 | 10:20 AM
EvoTech's Avatar
I really don't think that there is a need to calibrate a brand new sensor. If it is showing around 14.7 at cruise it should be good. At least that is what I have been told by Al from Dynoflash. What Map was this run with? You should really run it up to 7K or higher for a log run.
Old Jan 15, 2005 | 10:55 AM
MalibuJack's Avatar
This doesnt appear to be a map.. its all ECU passthrough or its a Map without any timing or boost control values..
In any case, if this is a passthrough, and your boost is manually set at 17psi, definitely has very conservative timing, and your never hitting any load site over 60.. Which is actually pretty normal considering your running 17psi of boost.. But your car probably feels pretty weak..
Anyone notice that at 2800-3000rpm the car seems to be around 1 degree AFTER TDC?? I've never seen that before on a WOT run...
What mods do you actually have on your car besides the UTEC.. I've never seen an airflow pattern like that before. Plus you have a weird intake airflow anomoly at 4852rpm kinda like your DV opened and recirculated just prior to that..
BTW you shouldn't have to worry about the calibration unless the sensor is old, or isn't reading 14.7 or so when cruising around in closed loop (at idle some cars read a little rich but should over around 14.7 most of the time)
YOu didn't make a full run to 7400rpm or so.. so its hard to tell what your high RPM looks like, but your correct in waiting until you get your wideband up and running..
Old Jan 15, 2005 | 04:28 PM
dryad001's Avatar
Well in the last thread you told me to make a few runs in the pass thru, so thats what I did. The only reason we didn't take it in the upper rpm band is that we kinda ran out of road, and we were coming up on the spot where I got my wing ticket. I finally got another laptop to use solely for the utec so I should be putting up more logs soon.
My mods consist of
264/272 cams
AEM intake
TB exhaust
pro-1 header
UR IC piping
Old Jan 15, 2005 | 09:41 PM
MalibuJack's Avatar
Ok... I talk to alot of people so I had a brainfart.. This is the first time I had seen the MAF results like that, likely due to the cams and lower boost.. Once you get your wideband setup, you'll be able to make a few more runs and we'll be able to suggest some settings..
Your mods are fairly similar to what many of us are running, so if the car feels good in stock mode (passthrough) you'll be pleasantly surprised with the gains once you start tuning.
Old Jan 15, 2005 | 09:48 PM
rraulston's Avatar
my latest. Just to compare....
Code:
    	     	     	   	Load	Knock	      	      	 Mod	  Mod	      	  Mod	  WB
 RPM	  MAP	  MAF	TPS	Site	Count	 Ign#1	 Inj#1	 Ign	  Fuel	Boost	  MAF	  AFR
    	  psia	  Hz	 % 	    	     	  deg 	 duty 	 deg	   %  	(OL) 	   Hz
836	27.6	32	0	0	0	3.2	1.1	ECU. 	0	ECU.  	24	14.58
846	27.6	33	0	0	0	3.2	1.1	ECU. 	0	ECU.  	24	14.58
896	27.6	33	0	0	0	1.4	1.1	ECU. 	0	ECU.  	23	14.61
2666	27.4	110	14	0	0	35.4	5	ECU. 	0	ECU.  	82	15.08
2658	27.4	112	14	0	0	35.5	3.5	ECU. 	0	ECU.  	80	15.08
2673	27.4	436	20	0	0	36.5	64.8	ECU. 	0	ECU.  	288	15.18
2677	27.4	255	100	10	0	29.4	8.6	ECU. 	0	ECU.  	244	15.5
2775	27.4	371	100	10	0	28.3	10.1	ECU. 	0	ECU.  	235	15.72
2858	27.4	452	100	10	0	26.6	11.3	ECU. 	0	ECU.  	234	16.19
2957	27.4	488	100	10	0	26.7	13.1	ECU. 	0	ECU.  	363	16.36
3013	27.2	574	100	10	0	25.6	14.6	ECU. 	0	ECU.  	328	15.87
3112	27.2	529	100	10	0	23.5	14.2	ECU. 	0	ECU.  	449	15.31
3223	27.2	648	100	10	0	20.7	19	ECU. 	0	ECU.  	444	14.87
3353	27.2	784	100	10	0	18.6	23.2	ECU. 	0	ECU.  	547	14.58
3461	27.2	1043	100	10	0	16.6	26.4	ECU. 	0	ECU.  	777	14.3
3623	27.4	868	100	30	0	11.7	37.2	ECU. 	0	ECU.  	954	14.22
3813	27.4	1089	100	40	0	10.6	40.5	ECU. 	0	ECU.  	976	13.97
4001	27.4	1128	100	50	0	11.1	41.1	ECU. 	0	ECU.  	978	13.36
4224	27.4	1355	100	50	0	11.4	42.3	ECU. 	0	ECU.  	816	12.99
4368	27.4	1298	100	60	0	10.7	41.4	ECU. 	0	ECU.  	989	12.81
4547	27.2	1355	100	60	0	10.8	47	ECU. 	0	ECU.  	968	12.78
4755	27	1470	100	60	0	9.7	48.1	ECU. 	0	ECU.  	1008	12.78
4975	27	1344	100	60	0	10.3	50	ECU. 	0	ECU.  	1171	12.56
5104	27.2	1497	100	70	0	10.4	52.2	ECU. 	0	ECU.  	1068	12.25
5307	27.2	1538	100	70	0	11.5	56.9	ECU. 	0	ECU.  	1071	12.09
5473	27.4	1592	100	80	0	11.4	54.3	ECU. 	0	ECU.  	1205	11.92
5602	27.4	1730	100	80	0	13	56.6	ECU. 	0	ECU.  	1182	11.73
5767	27.4	1587	100	80	0	14	57.1	ECU. 	0	ECU.  	1279	11.56
5931	27.4	1623	100	90	0	12	59.7	ECU. 	0	ECU.  	1311	11.45
6071	27.4	1754	100	90	0	13.6	62.1	ECU. 	0	ECU.  	1284	11.33
6218	27.4	1694	100	90	0	16.2	63.8	ECU. 	0	ECU.  	1284	11.23
6361	27.4	1712	100	100	0	17	63.2	ECU. 	0	ECU.  	1320	11.14
6510	27.4	1779	100	100	0	18.3	66.2	ECU. 	0	ECU.  	1388	11.14
6626	27.2	1818	100	100	0	18.8	61.2	ECU. 	0	ECU.  	1373	11.11
6747	27.2	1785	100	100	0	21.3	70.5	ECU. 	0	ECU.  	1213	11.11
6887	27.2	1831	100	100	0	22.4	68.7	ECU. 	0	ECU.  	1447	11.11
7002	27.2	1811	100	100	0	23.5	69.2	ECU. 	0	ECU.  	1338	11.05
7107	27.2	1694	100	100	0	23.5	70.3	ECU. 	0	ECU.  	1348	10.9
7215	27.2	1872	100	100	0	24	72.8	ECU. 	0	ECU.  	1436	10.59
7309	27.2	1851	100	100	0	24.1	74.3	ECU. 	0	ECU.  	1358	10.42
7423	27.2	1893	100	100	0	25	70.8	ECU. 	0	ECU.  	1404	10.43
7507	27.4	1824	100	100	0	25	72.5	ECU. 	0	ECU.  	1383	10.46
7610	27.4	1945	100	100	0	26.1	75.2	ECU. 	0	ECU.  	1329	10.52
7627	27.4	1818	100	100	0	22.3	71.5	ECU. 	0	ECU.  	1373	11.01
7440	27.4	504	1	0	0	32.6	13.5	ECU. 	0	ECU.  	123	13.39
6988	27.4	160	1	0	0	38.7	10.8	ECU. 	0	ECU.  	158	16.89
6485	27.4	221	0	0	0	38.5	5.8	ECU. 	0	ECU.  	119	15.12
5995	27.4	95	0	0	0	38.5	4.9	ECU. 	0	ECU.  	107	14.25
5630	27.4	77	1	0	0	28.4	9	ECU. 	0	ECU.  	48	13.95
Old Jan 15, 2005 | 09:50 PM
rraulston's Avatar
my car ramps up so fast, its scarry.....
Old Jan 15, 2005 | 10:23 PM
MalibuJack's Avatar
Code:
Damn, there's that anomoly on yours too.. Damn, alot of ECU timing at where you should be getting peak boost..
Its interesting to see how different these cars are..
Old Jan 16, 2005 | 07:25 AM
rraulston's Avatar
my car ramps up so fast, i might have to start doing 4th gear pulls. I just hate going that fast on the streets. All that timing is on map 0 which ime assuming is the TXS background map. Or is it factory ECU??? I dont know, but I HIGHLY recommend HKS 272/272. I have no stalling issues and idle is only slightly choppy to where it sounds like an old lumpy big cam v-8, which i happen to like. DRYAD: lets see another one of yours with wideband... RRR
Old Jan 16, 2005 | 08:13 AM
MalibuJack's Avatar
Yeah thats your Factory ECU doing that.. It blew me away, but likely because the MAF readings are so low (20% lower if you look at the modified MAF output)
I like the lope on the cams too, I haven't installed them in my car but I tuned two cars with 272's.. one had them straight up, the other had -4/-1 It was actually more difficult to get the staggered timing to run and idle right than the 0/0.. The staggered timing seemed to load up and swing wildly between rich and lean, more than my car with the blowthrough MAF did..
Old Jan 16, 2005 | 08:23 AM
rraulston's Avatar
Hey Jack, if i have my 780's scaled, by the way, 650cc was perfect to scale the 780's, Can i still run MAP-0?? or do i have to go to map 1 and stay there?? The documentation is way to LEAN!!!! Ray
Old Jan 16, 2005 | 08:42 AM
SoR's Avatar
SoR
Originally Posted by MalibuJack
Code:
Do you think anomaly is showing because his car is running super lean at peak boost? Mine used to do be very lean too however I didn't notice MAF drop but I had to add sh1tl0ad of fuel between 3k and 4500
(just noticed how load maps change too quick - damn)
Old Jan 16, 2005 | 11:25 AM
MalibuJack's Avatar
It looks as if the passthrough is actually scaling the MAF output.. But it definitely looks like your real lean until about 4500rpm anyway.. Your not getting any knock picked up by the UTEC, but I do see the ECU wanting to pull a little timing here and there..
I figured by seeing those numbers that you had scaling enabled..
What I found was interesting is how the MAF frequency jumps as much as 200hz and then drops, then jumps again.. Thats typically turbulence on my car, when my car feels like its stumbling (like a misfire) Thats the kind of anomoly I'd pick up, I don't get that any longer...
Anyway, the short answer is it seems like you can run Map0 if you had to.. perhaps set the scaling a little fatter if you want to do that so when boost ramps, it doesn't tip in quite as lean, but it seems like the ECU picks this up and adjusts for it after some time (It did on my car)
I don't see anything really wrong with whats going on, but since the MAF is scaled about 10-20% leaner than stock, but you have bigger injectors, your fueling is more or less fine (though a bit lean from 2000-3800rpm), but the stock ECU is thinking theres less load and running more timing..
I love seeing this data because some of it is similar to things I've seen before, and others are just unlike anything I've worked with before.
