wierd utec problem - random mod maf numbers
Old Feb 10, 2005 | 09:17 AM
ny-quiL's Avatar
I just got this utec a week or so ago (no tuner yet so no afr data) - the first night i installed it car started, ran fine and i did some logging on the drive home. when i got home i noticed this wierd number that kept showing up in the mod maf column randomly (3392). I didnt really think much of it, and i did some more logging throughout the week and didnt notice it again. I started getting a little misfire due to older bpr7es's so i replaced them last night. Now the wierd number is back, along with another (9464...yes nine THOUSAND). I cannot find any pattern to this seems to be very random - when it shows up my maf reading is fine, not jumpy at all. Please take a look at the attached log and advise - sorry the logs are stop and go traffic on my way to work, i tried to get a couple WOT spots in -notice the maf only goes as high as 1600hz then
- thanks
my mods are buschur cat back, turbo xs mbc set for 19psi (settles to 18), cone style intake mounted on maf, greddy type-s
File Type: zip
Old Feb 10, 2005 | 04:13 PM
superman105's Avatar
by looking at your mods I would suggest you change back your stock AirBox and see if the problem goes away. Evo with Aftermarket Air Filter and Pipes are sometimes troublesome
Old Feb 13, 2005 | 04:37 PM
bbbwrx's Avatar
It seems that the number shows up right before a slight decrease in idle. I can't really explaine why though. Just a pattern I noticed
Ben
